'com.example.plugins.tutorial.duedate:due-date-indicator' error in the view issue page web panel
vikram ummagani October 17, 2017
Hi Team,
I am trying to create due-date-indicator plugin for jira service-desk, which shows a web panel in the view issue page and shows days remaining from the due date which is set during the creation of an issue. But when I run my plugin using atlas commands I am able to see my plugin and modules enabled in the Jira UI. But it is showing the following error in the Jira view issue page web panel:
Error rendering 'com.example.plugins.tutorial.duedate:due-date-indicator'. Please contact your JIRA administrators.
Following is the code which I have used in respective files:
code for atlassian-plugin.xml:
<?xml version="1.0" encoding="UTF-8"?>
<atlassian-plugin key="${atlassian.plugin.key}" name="${project.name}" plugins-version="2">
<plugin-info>
<description>${project.description}</description>
<version>${project.version}</version>
<vendor name="${project.organization.name}" url="${project.organization.url}"/>
<param name="plugin-icon">images/pluginIcon.png</param>
<param name="plugin-logo">images/pluginLogo.png</param>
</plugin-info>
<!-- add our i18n resource -->
<resource type="i18n" name="i18n" location="duedate"/>
<!-- add our web resources -->
<web-resource key="duedate-resources" name="duedate Web Resources">
<dependency>com.atlassian.auiplugin:ajs</dependency>
<resource type="download" name="duedate.css" location="/css/duedate.css"/>
<resource type="download" name="duedate.js" location="/js/duedate.js"/>
<resource type="download" name="images/" location="/images"/>
<context>duedate</context>
</web-resource>
<!-- <component-import key="applicationProperties" interface="com.atlassian.sal.api.ApplicationProperties"/>-->
<web-panel name="DueDateIndicator" i18n-name-key="due-date-indicator.name" key="due-date-indicator" location="atl.jira.view.issue.right.context" weight="1000">
<description key="due-date-indicator.description">The DueDateIndicator Plugin</description>
<abstract-jira-context-provider class="com.example.DueDateIndicator"/>
<!-- <context-provider class="com.example.plugins.tutorial.DueDateIndicator"/>-->
<!-- <context-provider class="com.atlassian.jira.plugins.tutorial.DueDateIndicator"/>-->
<resource name="view" type="velocity" location="due-date-indicator.vm"/>
<!-- <label key="due-date-indicator.title"/>-->
</web-panel>
</atlassian-plugin>
code for DueDateIndicator.java:
package com.example.plugins.tutorial;
import com.atlassian.jira.user.ApplicationUser;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.plugin.webfragment.contextproviders.AbstractJiraContextProvider;
import com.atlassian.jira.plugin.webfragment.model.JiraHelper;
//import com.atlassian.jira.user.util;
import java.sql.Timestamp;
import java.util.HashMap;
import java.util.Map;
public class DueDateIndicator extends AbstractJiraContextProvider
private static final int MILLIS_IN_DAY = 24 * 60 * 60 * 1000;
@Override
public Map getContextMap(User user, JiraHelper jiraHelper) {
Map contextMap = new HashMap();
Issue currentIssue = (Issue) jiraHelper.getContextParams().get("issue");
Timestamp dueDate = currentIssue.getDueDate();
if (dueDate != null)
int currentTimeInDays = (int) (System.currentTimeMillis() / MILLIS_IN_DAY);
int dueDateTimeInDays = (int) (dueDate.getTime() / MILLIS_IN_DAY);
int daysAwayFromDueDateCalc = dueDateTimeInDays - currentTimeInDays + 1;
contextMap.put("daysAwayFromDueDate", daysAwayFromDueDateCalc);
return contextMap;
@Override
public Map getContextMap(ApplicationUser arg0, JiraHelper arg1) {
//TODO Auto-generated method stub
return null;
code for pom.xml:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>com.example.plugins.tutorial</groupId>
<artifactId>duedate</artifactId>
<version>1.0-SNAPSHOT</version>
<organization>
<name>Example Company</name>
<url>http://www.example.com/</url>
</organization>
<name>duedate</name>
<description>This is the com.example.plugins.tutorial:duedate plugin for Atlassian JIRA.</description>
<packaging>atlassian-plugin</packaging>
<dependencies>
<dependency>
<groupId>com.atlassian.jira</groupId>
<artifactId>jira-api</artifactId>
<version>${jira.version}</version>
<scope>provided</scope>
</dependency>
<!-- Add dependency on jira-core if you want access to JIRA implementation classes as well as the sanctioned API. -->
<!-- This is not normally recommended, but may be required eg when migrating a plugin originally developed against JIRA 4.x -->
<dependency>
<artifactId>jira-core</artifactId>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.10</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>com.atlassian.plugin</groupId>
<artifactId>atlassian-spring-scanner-annotation</artifactId>
<version>${atlassian.spring.scanner.version}</version>
<scope>compile</scope>
</dependency>
<dependency>
<artifactId>atlassian-spring-scanner-runtime</artifactId>
<scope>runtime</scope>
</dependency>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
</dependency>
<!-- WIRED TEST RUNNER DEPENDENCIES -->
<dependency>
<groupId>com.atlassian.plugins</groupId>
<artifactId>atlassian-plugins-osgi-testrunner</artifactId>
<version>${plugin.testrunner.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>jsr311-api</artifactId>
<version>1.1.1</version>
</dependency>
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.2.2-atlassian-1</version>
</dependency>
<!-- Uncomment to use TestKit in your project. Details at https://bitbucket.org/atlassian/jira-testkit -->
<!-- You can read more about TestKit at https://developer.atlassian.com/display/JIRADEV/Plugin+Tutorial+-+Smarter+integration+testing+with+TestKit -->
<dependency>
<groupId>com.atlassian.jira.tests</groupId>
<artifactId>jira-testkit-client</artifactId>
<version>${testkit.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.8.5</version>
<scope>test</scope>
</dependency>
</dependencies>
<build>
<plugins>
<plugin>
<groupId>org.apache.maven.plugins</groupId>
<artifactId>maven-compiler-plugin</artifactId>
<version>3.5.1</version>
<configuration>
<source>1.8</source>
<target>1.8</target>
</configuration>
</plugin>
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>maven-jira-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
<!-- Uncomment to install TestKit backdoor in JIRA. -->
<pluginArtifacts>
<pluginArtifact>
<artifactId>jira-testkit-plugin</artifactId>
</pluginArtifact>
</pluginArtifacts>
<enableQuickReload>true</enableQuickReload>
<enableFastdev>false</enableFastdev>
<!-- See here for an explanation of default instructions: -->
<!-- https://developer.atlassian.com/docs/advanced-topics/configuration-of-instructions-in-atlassian-plugins -->
<instructions>
<Atlassian-Plugin-Key>${atlassian.plugin.key}</Atlassian-Plugin-Key>
<!-- Add package to export here -->
<Export-Package>com.example.plugins.tutorial.api,</Export-Package>
<!-- Add package import here -->
<Import-Package>org.springframework.osgi.*;resolution:="optional", org.eclipse.gemini.blueprint.*;resolution:="optional", *</Import-Package>
<!-- Ensure plugin is spring powered -->
<Spring-Context>*</Spring-Context>
</instructions>
</configuration>
</plugin>
<plugin>
<artifactId>atlassian-spring-scanner-maven-plugin</artifactId>
<executions>
<execution>
<goals>
<goal>atlassian-spring-scanner</goal>
</goals>
<phase>process-classes</phase>
</execution>
</executions>
<configuration>
<scannedDependencies>
<dependency>
<artifactId>atlassian-spring-scanner-external-jar</artifactId>
</dependency>
</scannedDependencies>
<verbose>false</verbose>
</configuration>
</plugin>
</plugins>
</build>
<properties>
<jdkLevel>1.8</jdkLevel>
<jira.version>7.2.2</jira.version>
<amps.version>6.2.11</amps.version>
<plugin.testrunner.version>1.2.3</plugin.testrunner.version>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<!-- This key is used to keep the consistency between the key in atlassian-plugin.xml and the key to generate bundle. -->
<atlassian.plugin.key>${project.groupId}.${project.artifactId}</atlassian.plugin.key>
<!-- TestKit version 6.x for JIRA 6.x -->
<testkit.version>6.3.11</testkit.version>
</properties>
</project>
my Jira version is 7.2.2, java version is 1.8.
Please help me.
Thanks in advance
Vikram
MoroSystems Support
October 17, 2017
Hi Vikram, what is the folders/files structure in the project?
Martin
vikram ummagani October 18, 2017
Hi Martin, here is the file system link which I am using for due-date-indicator
https://drive.google.com/open?id=0B7h9IWYFDXOgYXBXN25sMlRpdlE
MoroSystems Support
October 18, 2017
please try to change:
</web-panel>
 to:
<resource name="view" type="velocity" location="/due-date-indicator.vm"/>
</web-panel>
note slash sign in location attribute.
Are there any errors logged in the JIRA log file?
vikram ummagani October 18, 2017 edited
Hi Martin,I have added the suggestion you  mentioned. But I am getting the following error when I run plugin:
[ERROR] Unable to complete running command: pi
java.lang.RuntimeException: org.apache.maven.plugin.MojoExecutionException: Unable to execute mojo
at org.twdata.maven.cli.commands.ExecuteGoalCommand.run(ExecuteGoalCommand.java:112)
at org.twdata.maven.cli.commands.ExecuteGoalCommand.run(ExecuteGoalCommand.java:107)
at org.twdata.maven.cli.CliShell.interpretCommand(CliShell.java:48)
at org.twdata.maven.cli.CliShell.run(CliShell.java:29)
at org.twdata.maven.cli.AbstractCliMojo.displayShell(AbstractCliMojo.java:174)
at org.twdata.maven.cli.AbstractCliMojo.access$000(AbstractCliMojo.java:22)
at org.twdata.maven.cli.AbstractCliMojo$1.run(AbstractCliMojo.java:123)
Caused by: org.apache.maven.plugin.MojoExecutionException: Unable to execute mojo
at org.shaded.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:174)
at org.shaded.mojoexecutor.MojoExecutor$ExecutionEnvironmentM3.executeMojo(MojoExecutor.java:476)
at org.shaded.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:75)
at org.twdata.maven.cli.MojoCall.run(MojoCall.java:33)
at org.twdata.maven.cli.commands.ExecuteGoalCommand.runMojo(ExecuteGoalCommand.java:126)
at org.twdata.maven.cli.commands.ExecuteGoalCommand.run(ExecuteGoalCommand.java:109)
... 6 more
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:174)
at org.twdata.maven.mojoexecutor.MojoExecutor$ExecutionEnvironmentM3.executeMojo(MojoExecutor.java:476)
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojo(MojoExecutor.java:75)
at com.atlassian.maven.plugins.amps.MavenGoals.installPlugin(MavenGoals.java:1448)
at com.atlassian.maven.plugins.amps.pdk.InstallMojo.execute(InstallMojo.java:17)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:133)
at org.shaded.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:172)
... 11 more
Caused by: org.apache.maven.plugin.MojoExecutionException: Install Plugin : Upload failed --- {"type":"INSTALL","pingAfter":100,"status":{"done":true,"statusCode":200,"contentType":"application/vnd.atl.plugins.task.install.err+json","subCode":"upm.pluginInstall.error.install.failed"},"links":{"self":"/jira/rest/plugins/1.0/pending/c646e5d7-feb6-4770-8b39-f25317264bce","alternate":"/jira/rest/plugins/1.0/tasks/c646e5d7-feb6-4770-8b39-f25317264bce"},"timestamp":1508331989375,"userKey":"admin","id":"c646e5d7-feb6-4770-8b39-f25317264bce"}
at com.atlassian.maven.plugins.pdk.InstallPluginMojo.uploadFile(InstallPluginMojo.java:184)
at com.atlassian.maven.plugins.pdk.InstallPluginMojo.execute(InstallPluginMojo.java:135)
at org.twdata.maven.mojoexecutor.MojoExecutor.executeMojoImpl(MojoExecutor.java:172)
... 17 more
Get Certified! ✍️
