×I am getting this error when trying to connect to JIRA server running local on my PC.
Jira server url: http://localhost:8080, I am just getting started to run jira and integrate within eclipse.
Any idea ?
Hi Parvesh,
The 301 error you're getting suggests that the connection is facing one of the following problems:
So, can I ask you to try connecting to your JIRA instance using the IP address of the server rather than localhost as I believe this will probably workaround the problem you are experincing.
All the best,
John
Hi
Sorry to piggy back on this thread, but I get the same error on a connection which has previously been working, using the URL of a remote JIRA instance.
I have not changed my settings, it just went away and will not longer sync. The odd thing is, if I select the 'view in browser' option, I am show the correct filter results within the exlipse browser window.
Any help much appreciated.
Nathan
Dang, that should have been a comment too. I double points there.
