completion date
Chag
August 12, 2014
is it possible to add a completion date like the due date in a field in jira?
Radu Dumitriu
August 12, 2014
Carl DiClementi
I typically accomplish this with the following steps:
  1. Create a custom field "Completed Date Time" of type Date Time Picker - see docs
  2. Customize your workflow transition to your "done" status by adding a post function that updates your new, custom field's value to %%CURRENT_DATETIME%% - see docs
Jose M.
November 22, 2014
Yes, it is possible, as previously answered. The "Date Picker" would be the same as the "Due Date", but in our case probably the "Date Time Picker" could be more helpful.
What do you think about the use of a 3rd-party-plugin, if this matter is of high importance for your business? Otherwise it could become a problem to update "Due Date", "Time Estimation" and "Completion Date" in parallel.
Alexey_Rjeutski__Polontech_
August 14, 2014
If you need simple date time picker - it is possible to add custom field with that type in default installation of jira. If you need some automatization of other field change - please give more details on the field behaviour.
Chag
August 14, 2014
what 3rd party plugin i can use for that?
Jose M.
August 14, 2014
I was thinking on a Gantt-Chart plugin, as the Gantt-Chart for Jira by Frank Polscheit.
