components should always be auto populated once a new project is created in instance.
Priyanka khare
Components should always be auto-populated once a new project is created. There is a particular set of components that every project should have and whenever a new project is created we have to add it manually, is there a way it can be done automaticlly?
Daniel Ebers
February 28, 2021
Hi @Priyanka khare
in case you have Apps available this will be possible.
I had an use case linke this where "Copy Project" Built-In Script of ScriptRunner worked out fine:
https://scriptrunner.adaptavist.com/latest/jira/builtin-scripts.html#_copy_project
You can optionally copy components using this to your project which is to be created/cloned.
Daniel
Jack Brickey
You should consider creating a project template and use that when creating a new project. Disclaimer, I am on Cloud and not sure if this is available on Server but expect it is. When I create a project I have the option to base the new project on an existing project.
Priyanka khare
Hello @Jack Brickey ,
I tried it and it did not copy the components. Do u know any other way? for JIRA server.
Priyanka Khare
Jack Brickey
unfortunately I do not. I was assuming components would come over but have not confirmed for myself and it seems at least for server it does not. :-(
Read the story
