Base from the documentation:
https://confluence.atlassian.com/adminjiraserver079/supported-platforms-950288096.html I do not need to install Java on a centos since I will use the linux bundle to install it.
I somehow successfully install it, however, upon executing ./config.sh, I got the following error
./config.sh
No JRE_HOME or JAVA_HOME environment variable is set - attempting to just run java command
********** Wrong JVM version! You are running with .. but JIRA requires at least 1.8 to run. **********
Weird enough, this should not happen because it is already a bundle.
Is there a way for me to fix this?
Additionally, when I execute ./version.sh I get the following results:
Server startup logs are located in /opt/atlassian/jira/logs/catalina.out
Using CATALINA_BASE: /opt/atlassian/jira
Using CATALINA_HOME: /opt/atlassian/jira
Using CATALINA_TMPDIR: /opt/atlassian/jira/temp
Using JRE_HOME: /opt/atlassian/jira/jre/
Using CLASSPATH: /opt/atlassian/jira/bin/bootstrap.jar:/opt/atlassian/jira/bin/tomcat-juli.jar
Using CATALINA_PID: /opt/atlassian/jira/work/catalina.pid
Server version: Apache Tomcat/8.5.6
Server built: Oct 6 2016 20:15:31 UTC
Server number: 8.5.6.0
OS Name: Linux
OS Version: 3.10.0-862.3.3.el7.x86_64
Architecture: amd64
JVM Version: 1.8.0_102-b14
JVM Vendor: Oracle Corporation
You need to run java -version and if no return, you need to reboot your server.
If you run java -version and return a version, you need to remove the java that is installed since Jira dont need the server to install it.
Hi @Moses Thomas,
I am trying to change port and explore the tool. I finally figure out to make it work;
1.) Uninstall java that was installed so when you execute java -version it should return null
2.) Restart server
On the changing of ports: there is a manual way to do it but I want to learn and explore the tool.
