configure workflow and requirement field
Stanislaw Palak December 2, 2012
hi,
how can configure workflow that when status is resolved and
resolution contain one option is for example (option 1, options 2, options 3) then filed fix version is requirement ?
thanks for help
C_ Faysal
December 2, 2012
hi Stanislaw,
you may have a look at the behaviours plugin
hi
is this possible without plugins ?
C_ Faysal
December 2, 2012
