I am trying to copy cascading field value of parent to into the same cascade field of sub-task while creation. I am using "Copy Value From Other Field Function for this transition".
Field A- Parent should be copied Field -A in sub-task while creation.
This is not working. If the sub-task is created, the field value is not inherited from parent. Or else the sub-task itself is not getting created. In the logs i could see the error unable to copy the field value of type cascading.
Please let me know how to copy the cascading field value.
Krithica
Hi @G Krithica ,
Using Create on Transition add-on you will be able to copy any type of custom field values from parent issue to subtask at the time of creation.
https://bobswift.atlassian.net/wiki/spaces/CSOT/pages/444366853/Workflow+Post+Functions+of+Create+on+Transition+-+7.x you can have a look for more configuration details.
Regards.
Sravya
Read the story
