×hi there
please can you help me?
I have an issue, with filled columns like Affects Version/s:, Component/s:, Environment and i want to create a subtask, which would have the same values as parent issue. How to set this? thank you
i used this plugin https://marketplace.atlassian.com/697735 - it can inherit system fields like components, affect version ... but you must edit the subtask, which is generated automatically - if you want to change summary or description
Jobin's plugin https://marketplace.atlassian.com/22274
Well, it doesn't support system fields :(
but this plugin allows to copy only custom fields ... affect version, component, environment are not custom fields... :(
Oh yeah :(
Jobin can extend it's features :) Or make the code open source :)
The code is all yours: https://studio.plugins.atlassian.com/source/browse/JCTS
Peter, now you have way to achieve your requirement :)
