Sign up Log in
could not find Edit Options for custom field.
pokalav
Hi team,
 I need to disable an option in a custom field, but I did not find any Edit Options link after configure .
we are using jira 7.10.0 datacenter version. Please help us to disable an option in future use.
Alexey Matveev
November 20, 2018
What is the type of the custom field? Could you make a screenshot of this custom field in the Issues -> Custom Field vew?
pokalav
Alexey Matveev
November 21, 2018
Click the Configure option. There will the Edit Options button:
pokalav
There is no Edit Options button after clicking Configure.
Alexey Matveev
November 21, 2018
And Product Line is a multi-select field?
pokalav
Yes, it is a multi-select field.
Alexey Matveev
November 21, 2018
It is not a single select custom type field. It has the Label Manager type. it means that this field is from a plugin and if a field is shown as a dropdown list, it does not mean that this field has a single select type. Moreover it means that it is not a single select type. It just looks like this on the screen.
pokalav
so ,Can't we disable option of this field?
Alexey Matveev
November 21, 2018
If the developer of this plugin does not provide this feature, then you can not disable an option.
pokalav
Using Groovy script?
Alexey Matveev
November 21, 2018
You should contact the developer of this plugin. I am not familiar with this plugin.
Nic Brough -Adaptavist-
November 21, 2018
I've seen this add-on before, it does not have options like multi-select lists because the list is generated by looking at your labels.
To change the options it offers you, you need to add or remove labels from the issues.
