i want to count how many checkbox options are selected! I've already seen something like this:
def count = 0;
def test1 = cfValues['Checkbox Customfield']?.getValue() == 'Option1';
def test2 = cfValues['Checkbox Customfield']?.getValue() == 'Option2';
if(test){
count++;
if(test2){
count++;
}However, this code does not work! Does anyone has another idea how it could work? Maybe in a less complicated way?
Best regards,
Louisa
So with the following code it works:
def numberselected = issue.getCustomFieldValue(ComponentManager.getInstance().getCustomFieldManager().getCustomFieldObjectByName("Checkbox Customfield")).size(); Thanks Nic for your help ![]()
Best regards,
Louisa
I'd go with
def numberselected = cfValues['Checkbox Customfield']?.getValue().size()
The getValue should be returning an array of all the currently selected options, so all you should need to do is count them, and you can do that with the size function.
Thank you for fast response! Unfortunately, it still does not work. Do I have to define cfValues? Or do I have to import anything to be able to use cfValues?
Ah, I was assuming you'd only given a snippet of script and had already dealt with fetching cfValues in a bit you hadn't posted. From scratch, you should be able to use this in a scripted field: def numberselected = getCustomFieldValue("Checkbox Customfield")?.getValue().size() If you're running this somewhere else, it may need to change.
I'll use it in a scripted postfunction! I tried: def numberselected = issue.getCustomFieldValue(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Checkbox Customfield"))?.getValue().size(); But it still does not work!
