×Hi,
I'm trying to use JQL when querying the JIRA API however I am getting a weird message:
Request:
curl --location --request GET 'https://confluence.aws.xxx.xxx/rest/api/search?jql=project=MYPROJ+order+by+status'
Response:
{ "statusCode": 400, "data": { "authorized": false, "valid": true, "allowedInReadOnlyMode": true, "errors": [], "successful": false }, "message": "cql query parameter is required", "reason": "Bad Request"}
Any idea what I am doing wrong?
Hi @Surugiu Iulian ,
Sorry , I did not understand the question correctly. Can you please elaborate little bit.
I can see you are trying to get the Jira data from Jira api but the rest end point you mentioned is for the confluence.
