create button or input text value
Bruno Bernadet July 22, 2021
hi
is this possible with not using a script add on rather a thing like vba from microsoft who propose graphical possibilities ?
thanks
no it's for example if i wanted to create automatically a test set name "xxxx based on a model all ready define. it could be by rest api with a json file.
i would like just for the user to write the name of the test set click a button linked to the call of the rest api with the parameters all define
Nic Brough -Adaptavist-
July 22, 2021
So nothing to do with a button or text field, you want to write a process that creates a test set.  Or rather that's just the very last part of your actual desire.
Have a look at the docs for whatever you are creating this "test set" in, and check to see what the API says about creating them.  Code for that, and then think about how you want to trigger it, in whatever application is best for hosting a trigger button.
If that application is Jira, you'll need an app that can provide a web-fragment - this is how buttons and other web-items are added to Jira's UI.
July 22, 2021
I think we need a bit more context on what you're actually trying to achieve here.
You can create "input text value" by adding fields to your issues.
If you don't mean that, we'll need more info to answer the question.
Register now
