hello there
my situation: I want to trigger a transition from status "In progress" to "Error" and this transition would open a screen, where i could enter some changes and the transition would create a subtask of the issue (the best: copy some fields from parent - affect version, environment ...).
ok, i figured it out ... i used this plugin: create-on-transition-plugin-2.3.0
https://marketplace.atlassian.com/697735
and this plugin can inherit system fields from parent !!! :)
