creating assignee from custom field value
Surender Reddy May 23, 2019 edited
Hi friends,
      I am creating 3 subtasks with Quick Subtasks for JIRA post function which looks like
 Creates the following subtasks according to this subtask template:
- NSS /  cfield:"Project Title:@inherit" cfield:"Date Request Received:@inherit"
The issue type for the subtasks is set to Access Termination NSS.
Created subtasks are prefixed by their parent issues summary: Yes .
this creates subtask my question of how can I add an assignee automatically from a custom field(user picker) value from parent. which code should I add? I tried some but failing to pull assignee from the custom field(user picker). please help @Antoine Berry @Tarun Sapra @
2 accepted
Surender Reddy May 31, 2019
Time (on server): Wed May 29 2019 09:55:25 GMT-0400 (Eastern Daylight Time)
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2019-05-29 09:55:25,898 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2019-05-29 09:55:25,899 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: EAP-444, actionId: 1, file: <inline script>
java.lang.NullPointerException
 at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896)
 at com.atlassian.jira.issue.Issue$getCustomFieldValue$7.call(Unknown Source)
 at Script84.run(Script84.groovy:7)
this is the error I am seeing can you help     @Antoine Berry
Antoine Berry
Hi @Surender Reddy ,
I do not use Quick Subtasks. Unfortunately, according to the documentation, it seems that you can only use @admin, @current or @inherit.
I could help if you have scriptrunner though.
Antoine
Surender Reddy May 24, 2019
yaa we use script runner  can you help with code and which post fuction to use
Thanks in advance
Antoine Berry
You should use a custom script post-function in the create transition of the sub-task workflow.
Use this code (replace the custom field id) :
int userPickerId = 12803
def userPicker = customFieldManager.getCustomFieldObject(userPickerId)
def userPickerValue = issue.getParentObject()?.getCustomFieldValue(userPicker)
issue.setAssignee(userPickerValue)
Antoine
image.png its showing error can see that please
Antoine Berry
Please save as is. It is showing an error because the groovy console is not detecting userPickerValue as an ApplicationUser object, but at execution time it will work.
Antoine
Surender Reddy May 29, 2019
Antoine Berry
You are using this script in a create transition right ? Make sure you make it the last postfunction. Also can you confirm the issue is created as a subtask ?
Antoine
Surender Reddy June 3, 2019
yes its in create transtion and this is the last post function .  this issue is created using multiple subtask post function in parent issue
- Security Groups /  cfield:"Project Title:@inherit" cfield:"Date Request Received:@inherit"
and the custom feilds are inherited from parent issue using
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.ModifiedValue
//Your custom field ID
int cfId = 11902
def cf = customFieldManager.getCustomFieldObject(cfId)
def cfValue = issue.getCustomFieldValue(cf)
def cfParentValue = issue.getParentObject().getCustomFieldValue(cf)
cf.updateValue(null, issue, new ModifiedValue(cfValue, cfParentValue), new DefaultIssueChangeHolder())
in a scriptrunner post funtion .  @Antoine Berry
Antoine Berry
What does the logs return if you add :
log.error("parent issue : " + issue.getParentObject())
log.error("user picker : " + userPicker)
between line 6 and 7 ?
sorry i did not get you what do you want me to add between 6 and 7 lines , i only have the code which you sent me
and the error for this code is
Time (on server): Mon Jun 03 2019 11:18:12 GMT-0400 (Eastern Daylight Time)
2019-06-03 11:18:12,488 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2019-06-03 11:18:12,492 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: EAP-462, actionId: 1, file: <inline script>
 at com.atlassian.jira.issue.Issue$getCustomFieldValue$4.call(Unknown Source)
 at Script108.run(Script108.groovy:7)
Antoine Berry
Yes, can you use this code instead :
Trying to track what is null here.
Like • Surender Reddy likes this
Still, there is an error showing, the transition is getting successful but post function is failing.
Time (on server): Mon Jun 03 2019 11:45:49 GMT-0400 (Eastern Daylight Time)
2019-06-03 11:45:49,954 ERROR [workflow.ScriptWorkflowFunction]: parent issue : EAP-436
2019-06-03 11:45:49,954 ERROR [workflow.ScriptWorkflowFunction]: user picker : null
2019-06-03 11:45:49,956 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2019-06-03 11:45:49,956 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: EAP-465, actionId: 1, file: <inline script>
 at Script115.run(Script115.groovy:9)
Antoine Berry
See, user picker is null, is 12803 the correct ID ? You mentioned  11907 before.
yaa sorry I was changing the code from few days so forgot that and the post function is successful now, no logs found. but the problem is the assignee of the subtask is still unassigned.
Antoine Berry
Now that is a lot of post functions ! If you log the value of userPickerValue, what do you get ?
Surender Reddy June 4, 2019
I am not sure about that can you tell how to log user picker value
Antoine Berry
use
int userPickerId = 11907
log.error("userPickerValue : " + userPickerValue)
 and paste the logs
it's returning the value of the custom field which is Eid of the Hiring manager.
2019-06-04 10:51:33,722 ERROR [workflow.ScriptWorkflowFunction]: userPickerValue : e0o12mw(e0o12mw)
Antoine Berry
Try this, I added two lines :
import com.atlassian.jira.issue.index.IssueIndexingService
issue.store()
ComponentAccessor.getComponent(IssueIndexingService).reIndex(issue)
super super
Its working hiring manager field value updated in subtasks assignee ..
great work @Antoine BerryBerry. Thank you so much for being with the issue until the end .
Like • Antoine Berry likes this
Antoine Berry
No problem ! Glad it worked out.
Cheers.
Like • David P_ Hicks likes this
Yashwanth Jakkula October 19, 2022
My requirement is - Set assignee Automatically based on field value called Approver within same issue, used below script, but not working. Execution is success but Assignee value is not changed.
int userPickerId = 28200
def userPickerValue = issue.getCustomFieldValue(userPicker)
issue.store()
Yashwanth Jakkula October 20, 2022
Made small change, it's working now.
