creating fields for the particular statuses
Deepika November 14, 2019 edited
can you please have a look on the screenshot and i need to create a fields in such a way that
the first row on the excel screenshot will be the statuses of the workflow and the second row will be the fields required
1.when the ticket is under status  "issue metadata" while creating a ticket it should display only the fields under "issue metadata" status
and when issue lifecycle status the it should only the listed fields
can anyone help me out in this
Joe Pitt
I don't fully understand your question. Are you asking if you can create fields tied to statuses? You can create custom fields and only put them on the transition screen into or out of a status and the view screen. That will prevent anyone editing them outside of the transition. If you want to only show them for editing while in the status, then no without a possible plugin or scripting.
