HI Experts,
I just wanted to know can we able to have a custom screen to do user defined operations like adding some values.
As i know there are only 3 screens in JIRA create issue edit issue and resolve issue screen.please correct if am wrong.
i need to create seperate screen to have my user defined operation is it possible.
Thanks in Advance
Kumar
Screens can be used in four places.
Issue View - when you look at an issue
Issue Edit - when you edit the issue
Issue Create - when you create one
Transitions - when you move issues from status to status
There is no such thing as "link a screen to a status" - it's complete nonsense in JIRA terms (and mostly useless in the real world too). What you probably want to do is use transition screens - different screens appear according to what you're doing to the issue.
thank you for your quick reply
but how to link a screen to a status of a workflow
can you please elaborate
in workflow config,one status can match one screen view
