customers can't see their own issues ?
Emmanuelle Arthaud May 18, 2017
Hello all,
i have started a new "JIRA service desk". i have created a customer, he can "create an issue", but after that, he has no way to modifly or access on his issue.
When i use the authorization assistant, it tells me the the customer is not in the "administrators" or "service desk teams" to be able to modify his own issue.
Is it normal ?
Best regards,
Stephane MIRAILLES
MIOS company
Nic Brough -Adaptavist-
May 18, 2017
A customer should see their own *requests*, but not the issues behind them.  They are limited to the portal, and the issues they (or their organisation) raise.
You say you've had your customer use "create an issue" - do you mean that they did it in plain JIRA, or do you mean they raised a request via a portal?
