×I have problem with JIRA Database Values Plugin installation.
I have performed installation by putting plugin file (database-values-plugin-1.3.jar) in JIRAPP/lib folder.
After installation plugin is disabled and this error is logged in atlassian-jira.log:
The following plugins failed to load: database-values-plugin: There was a problem loading the descriptor for module 'Database Values Selection Field' in plugin 'database-values-plugin'. Error retrieving dependency of class: org.deblauwe.jira.plugin.databasevalues.DatabaseValuesCFType. Missing class: com/atlassian/jira/issue/customfields/SortableCustomField
I have tried installation on production server:
OS: Red Hat Enterprise Linux ES release 4 (Nahant Update 6)
Java: jdk1.6.0_27
JIRA: enterprise 4.3.3
After unsuccessful installation on production server I have tried installation on virtual server (virtualbox).
OS: CentOS release 5.8 (Final)
And most combinations of:
Java: java6u27 and java6u31
Jira versions: 4.3.3, 4.2.2 and 4.4.1
Plugin versions: 1.2 and 1.3
Database: mysql and HSQL
Windows VM:
OS: Windows XP sp3
JAVA: 1.6.0_31
Jira version: 4.2.2-b589
Plugin version: 1.3
In every combination I have tried I have same error.
Complete error from log:
___ Starting the JIRA Plugin System _________________ 2012-04-11 10:04:09,948 main INFO [atlassian.plugin.manager.DefaultPluginManager] Initialising the plugin system 2012-04-11 10:04:17,669 main ERROR [atlassian.plugin.manager.DefaultPluginManager] There was an error loading the descriptor 'Database Values Selection Field' of plugin 'org.deblauwe.jira.plugin.database-values-plugin'. Disabling. com.atlassian.plugin.PluginParseException: Error retrieving dependency of class: org.deblauwe.jira.plugin.databasevalues.DatabaseValuesCFType. Missing class: com/atlassian/jira/issue/customfields/SortableCustomField at com.atlassian.plugin.module.LegacyModuleFactory.getModuleClass(LegacyModuleFactory.java:50) at com.atlassian.plugin.descriptors.AbstractModuleDescriptor.loadClass(AbstractModuleDescriptor.java:176) at com.atlassian.plugin.descriptors.AbstractModuleDescriptor.enabled(AbstractModuleDescriptor.java:423) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl.enabled(CustomFieldTypeModuleDescriptorImpl.java:48) at com.atlassian.multitenant.plugins.MultiTenantModuleDescriptorFactory$LifecycleInterceptor.handleEnabled(MultiTenantModuleDescriptorFactory.java:246) at com.atlassian.multitenant.plugins.MultiTenantModuleDescriptorFactory$LifecycleInterceptor.intercept(MultiTenantModuleDescriptorFactory.java:183) at com.atlassian.jira.plugin.customfield.CustomFieldTypeModuleDescriptorImpl$$EnhancerByCGLIB$$88fd6779.enabled(<generated>) at com.atlassian.plugin.manager.DefaultPluginManager.notifyModuleEnabled(DefaultPluginManager.java:1429) at com.atlassian.plugin.manager.DefaultPluginManager.enableConfiguredPluginModule(DefaultPluginManager.java:1240) at com.atlassian.plugin.manager.DefaultPluginManager.enableConfiguredPluginModules(DefaultPluginManager.java:1207) at com.atlassian.plugin.manager.DefaultPluginManager.addPlugins(DefaultPluginManager.java:704) at com.atlassian.plugin.manager.DefaultPluginManager.init(DefaultPluginManager.java:170) at com.atlassian.jira.plugin.JiraPluginManager.start(JiraPluginManager.java:59) at com.atlassian.jira.ComponentManager$PluginSystem.start(ComponentManager.java:1380) at com.atlassian.jira.ComponentManager.quickStart(ComponentManager.java:254) at com.atlassian.jira.ComponentManager.start(ComponentManager.java:237) at com.atlassian.jira.upgrade.ConsistencyLauncher.launchConsistencyChecker(ConsistencyLauncher.java:61) at com.atlassian.jira.upgrade.ConsistencyLauncher.start(ConsistencyLauncher.java:39) at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:39) at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:57) at com.atlassian.jira.startup.LauncherContextListener$1.create(LauncherContextListener.java:52) at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.get(MultiTenantComponentMapImpl.java:121) at com.atlassian.multitenant.impl.MultiTenantComponentMapImpl.onTenantStart(MultiTenantComponentMapImpl.java:165) at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:134) at com.atlassian.multitenant.impl.DefaultMultiTenantManager$1.consume(DefaultMultiTenantManager.java:131) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForEachListener(DefaultMultiTenantManager.java:256) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startTenant(DefaultMultiTenantManager.java:130) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.startAll(DefaultMultiTenantManager.java:203) at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:85) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205) at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) at org.apache.catalina.core.StandardHost.start(StandardHost.java:840) at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053) at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463) at org.apache.catalina.core.StandardService.start(StandardService.java:525) at org.apache.catalina.core.StandardServer.start(StandardServer.java:754) at org.apache.catalina.startup.Catalina.start(Catalina.java:595) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289) at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414) Caused by: java.lang.NoClassDefFoundError: com/atlassian/jira/issue/customfields/SortableCustomField at java.lang.ClassLoader.defineClass1(Native Method) at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631) at java.lang.ClassLoader.defineClass(ClassLoader.java:615) at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:141) at java.net.URLClassLoader.defineClass(URLClassLoader.java:283) at java.net.URLClassLoader.access$000(URLClassLoader.java:58) at java.net.URLClassLoader$1.run(URLClassLoader.java:197) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:190) at java.lang.ClassLoader.loadClass(ClassLoader.java:306) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1667) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1526) at com.atlassian.plugin.util.ClassLoaderUtils.loadClass(ClassLoaderUtils.java:40) at com.atlassian.plugin.impl.StaticPlugin.loadClass(StaticPlugin.java:21) at com.atlassian.plugin.module.LegacyModuleFactory.getModuleClass(LegacyModuleFactory.java:27) ... 43 more Caused by: java.lang.ClassNotFoundException: com.atlassian.jira.issue.customfields.SortableCustomField at java.net.URLClassLoader$1.run(URLClassLoader.java:202) at java.security.AccessController.doPrivileged(Native Method) at java.net.URLClassLoader.findClass(URLClassLoader.java:190) at java.lang.ClassLoader.loadClass(ClassLoader.java:306) at java.lang.ClassLoader.loadClass(ClassLoader.java:247) ... 59 more
See https://studio.plugins.atlassian.com/wiki/display/JDVP/JIRA+Database+Values+Plugin#JIRADatabaseValuesPlugin-Installation for information on how to install the plugin. It is a "plugins one" plugin, which means you have to install it in the WEB-INF/lib folder.
Let me know if you might have other problems.
regards,
Wim
That was solution :)
As usual problem was in only step I assumed it was correct.
Thank you
