db-config.xml shows oracle10g after Jira 7 upgrade, why not oracle12c
Nazia Tarannum
May 25, 2016
Why do I see oracle10g in db-config.xml after upgrading to JIRA v7.1.2, should we manually change this to oracle12c ?
<jira-database-config>
  <name>defaultDS</name>
  <delegator-name>default</delegator-name>
  <database-type>oracle10g</database-type>
  <jdbc-datasource>
    <url>jdbc:oracle:thin:@//xxx.xxy.com:1525/xxxyzz</url>
MORESIMP _ Atlassian Solution Partner
August 16, 2016
appearently it's a bug of sorts.
it causes nothing more than confusion.
so at least it works.
not sure if Atlassian is working on the problem since they try to side PostgreSQL.
I hope this confirmation of "working fine" helps.
