I am using a listtype custom field which have multiple context created as per project being used.
I have used sdk to create a template via which i configure the default configuration for any new project along with creating a new config scheme for that custom field.
But I also want to copy the options from default scheme for new scheme created ??
Hello Chandan,
Unfortunately, there is no way to copy the options of a created contexts, however, maybe this Script Runner plugin in-built Script can help you, as mentioned on the answer below:
Help us plant more trees
