We have changed the default description of two default priorities in our JIRA. If we create an issue and click beneath the priority-field on the "?" we will see the "old" (JIRA-Standard) description and not our changed one.
If we open the priorities we'll see beneath the priorities our description.
What could we do to update the description in the view about the "?" ?
Hi Juliane,
I've got around to test this, and indeed; whatever you type as a description to the default priorities does not reflect when viewing the helo ("?" icon) when creating issues.
I've looked through the JIRA bug tracker, and found this: [JRA-28051] Customised priority description is not displayed in the priority help window if the priority name is not customised. Looking at this, it seems that this is just been recently fixed and awaiting deployment. I believe once this fix has been rolled into the new release of JIRA, you can then start modifying the priorities again. :)
like description in your link:
where did you change the description? See https://confluence.atlassian.com/display/JIRA/Defining+%27Priority%27+Field+Values
