×Hello community,
I have to read several jira fields directly from the database. For one field I'm getting problems because I don't know how I can read the "sprint"-value.
My basic table is the "jira.jiraissue". Who can tell me which select of joins/unions I have to take to get the "sprint"-value. Every issue will be solved in a sprint.
Thanks.
Further, I analyzed the other tables and I found out that my search sprint was stored in the tables:
AO_60DB71_SPRINT
USERHISTORYITEM
Hi, thanks for your hint. I've already read the both tables but I can't get the value. Do you know if there exists another table with sprint values?
I guess you would need to join customfield, customfieldvalue and AO_XXXXX_sprint.
