double authentication
lkrpoun_home March 20, 2017
I am looking into securing the user authentication. I saw two layer authentication can be implemented with bitbucket. Can we have the same with JIRA?
Any type of double authentication is ok with me.
Laurence
Niclas Sandstroem
March 20, 2017
Hi Laurence,
Intenso has written a quite recent post on the subject recently.
https://www.intenso-group.com/en/how-to-implement-two-factor-authentication-2fa-in-atlassian-apps/
Br, Niclas
Titus
November 30, 2017
Hi Laurence,
you can use the add-ons provided by SecSign Inc. to enable two-factor authentication at Confluence (or JIRA or Atlassian Crowd).
The solution of SecSign does not depend on additional hardware like usb tokens. You use your smartphone as second factor. Therefor the solution by SecSign is a true 2-factor authentication and a 2-channel authentication as well.
The add-ons provided by SecSign Inc. can be found at:
2FA add-on for JIRA by SecSign
SecSign 2FA add-on for Confluence
SecSign 2FA add-on for Atlassian Crowd
Information about the installation process and the login procedure can be found at:
SecSign ID JIRA tutorial
SecSign ID Confluence tutorial
SecSign ID Crowd tutorial
Titus
