hi
I have this problem when importing data from JIRA 6.2.6 backup in to JIRA 6.2 for downgrade
ErrError importing data: java.lang.IllegalArgumentException: [GenericEntity.set] "jobData" is not a field ofor importing data: java.lang.IllegalArgumentException: [GenericEntity.set] "jobData" is not a field of
--use jdk 1.7.71
---mysql 5.5
pls help me
Hello Yosef,
You may check the workaround described here and confirm if it applies to you.
Rodrigo Rosa
Hello Rodrigo I did not find the solution in your proposed route... But I ask this solution might be found Regards,
