With v3 of Drag and Drop (Jira 6.0.3), there appear to be errors in the JavaScript that cause issues with multiple pages.
For example, when browsing an issue:
When trying to view an issue filter, the page is rendered with only a single column, the left most list. The rest of the page and all the div boarders are displaced.
Attached is a screen shot of the JavaScript errors reported in Chrome. With the DND v3 add-on disabled these errors are no longer present.
We were super-excited to see IE10 support, but for now I've gone back to 2.10.
Thx for any help you can provide!
Bryan
Hello, this was just fixed, please upgrade to 3.0.1
Better, but 2 of the 3 anomolies I found without looking too hard are still present.
The Hide/Unhide carrot works great with v3.0.1, but in-line editing is still inoperative when the add-on is enabled. Also, the formating of the Issue Filter results are bunged up. See attached. This is a filter with a result of four issues in Detail view. I can't change the view with the DnD add-on enabled because buttons are gone, but with the result set in List view, the page is still off, but not quite as bad as the Detail view in the screen shot.
Also attached are the JavaScript errors present when the add-on is enabled (on the Issue Filter Detail view page. They are not present when the add-on is disabled.
Thanks for the quick response! If this is better tracked in an actual Jira issue, please let me know and I'll copy content over there.
Cheers!
Bryan
While I can't help Bryan at all, I wanted to chime in. We are running 6.1.4 and were very excited to see DnD updated. After updating, it is working great in FF, Chrome, IE 10/11.
But we can not use it at this point. Our main user base in on IE 8. When the plug-in is enabled, you can not view an issue. There are JS errors thrown within IE 8.
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; .NET4.0E) Timestamp: Tue, 3 Dec 2013 13:42:56 UTC Message: Array or arguments object expected Line: 2048 Char: 375 Code: 0 URI: http://jira-dev....com/s/d41d8cd98f00b204e9800998ecf8427e/en_US-1tggpb-1988229788/6159/110/07aa75f793be7ab9fe8ee9e13a0d6a22/_/download/contextbatch/js/jira.view.issue,-jira.navigator.simple,-jira.navigator.advanced/batch.js Message: Array or arguments object expected Line: 2048 Char: 375 Code: 0 URI: http://jira-dev....com/s/d41d8cd98f00b204e9800998ecf8427e/en_US-1tggpb-1988229788/6159/110/07aa75f793be7ab9fe8ee9e13a0d6a22/_/download/contextbatch/js/jira.view.issue,-jira.navigator.simple,-jira.navigator.advanced/batch.js
So, thank you for the update, but we still can't use this awesome plug-in.
Does anyone have any ideas or things I can try to get this to work?
Steve
We are experiencing the same issue! DnD v3, jira 6.1.4, IE8. Any assistance is highly appreciated!
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E) Timestamp: Tue, 3 Dec 2013 11:21:03 UTC Message: Array or arguments object expected Line: 298 Char: 375 Code: 0 URI: https://xxxxxxx/jira/s/d41d8cd98f00b204e9800998ecf8427e/en_UK-fna5gt-1988229788/6159/54/d947e3cf38162ead025a0067478d25c8/_/download/contextbatch/js/jira.view.issue,-jira.navigator.simple,-jira.navigator.advanced/batch.js
