I wrote a post function with python using jira scripting suite. it doesnt show duedate. what is wrong with my code
from com.atlassian.jira.issue import Issue from java.sql import Timestamp import java from java.util import Calendar cal = Calendar.getInstance(); ts=long(cal.getTimeInMillis()) issue.setDueDate(java.sql.Timestamp(ts))
I think that the problem is in the type of date , due date support only Date type and not date with time
https://answers.atlassian.com/questions/44314/how-to-set-full-date-for-duedate-field-on-jira
