Hi all, here is the backgroud.
We have a single select list named "service category", which has many options. And I hope it can be dynamic displayed base on issue type change when user submit or edit issues.
For example, when user submit case and choose issue type A, the "service category" field only show A,B and C options. But when user choose issue type B, the field will show other options D and E. I hope it can also work when user edit issue type and "service category" field in a existed issue.
I know it can be done by Behaviours, but I'm a script newbie, could someone tell me how to write the script?
Thank you very much!
Here is how I would do this...
// some apis we'll use
def customFieldManager = ComponentAccessor.customFieldManager
def optionsManager = ComponentAccessor.optionsManager
// first, define a variable to contain all your mapping,
// this way you just need to update this in the future and
// not have to worry about the code logic
// by convention, I like to use the lowercase everywhere
def typeCategoryMap = [
issuetypea : ['optiona','optionb', 'optionc'],
issuetypeb : ['optiond','optione'],
//find the category list based on the current issuetype
def categories = typeCategoryMap.find{ it.key == issueContext.issueType.name.toLowerCase()}
//build an option map based on the full list of option values
//first we need to get a custom field object
def cfServiceCategory = customFieldManager.getCustomFieldObjectByName("Service Category")
//next we need a configuration obejct based on the current issue context
def config = cfServiceCategory.getRelevantConfig(issueContext)
//finally we can get the full list of options for that context
def allOptions = optionsManager.getOptions(config)
//now we filter the allOptions for just the list we want
def applicableOptions = allOptions.findAll{it.value.toLowerCase() in categories}
def categoryFld = getFieldByName('Service Category')
//to protect against field name changes, the following is moresecure, you need to lookup your field id
//def categoryFld = getFieldById(123456)
categoryFld.setFieldOptions(applicableOptions)
Hi @PD Sheehan , it doesn't work on the test env. When submit case, there is nothing under ServiceCategory field.
Script below:
Purchasing : ['LCD','Laptop', 'RAM'],
Misc : ['Others'],
def categories = typeCategoryMap.find{ it.key == issueContext.issueType.name}
def cfServiceCategory = customFieldManager.getCustomFieldObjectByName("ServiceCategory")
def applicableOptions = allOptions.findAll{it.value in categories}
def categoryFld = getFieldByName('ServiceCategory')
It's hard to know why it's not working without actually being there and trying.
The way I would try to investigate the reason is to output several debug messages:
//make sure debuging missages are visible
log.setLevel(org.apache.log4j.Level.DEBUG)
log.info "Start of behavior debugging"
Misc : ['Others'],
log.debug "Issue Type Detected: $issueContext.issueType.name"
log.debug "Categories found: $categories"
log.debug "ServiceCategory custom field object: $cfServiceCategory"
log.debug "Full list of ServiceCaegory options: ${allOptions*.value}"
log.debug "Applicable options: ${applicableOptions*.value}"
Then review or tail your [jira-home]/log/atlassian-jira.log for messages, that should help pinpoint where things went wrong.
