I have set up an interval for a custom number field called “Time to Notify Customers” in eazyBI, and I have set up a timeline graph (see image) to show the number of issues in each interval over time. I am trying to find a way to display this as a percentage over time of issues that are in the ‘000 – 030’ interval, but I can’t figure out how to do it. Is there a way to accomplish this? I'm assuming I have to create a calculated member but I'm not sure what the formula should be.
Hi Evan! The plugin 'eazyBI' was created by a third party developer, so you'll be more likely to receive an answer on this if you contact their support team directly.
Once you get an answer, It would be awesome if you share it here so the rest of the Community can benefit from it as well :)
Ana
