emoticons in JIRA result in "Communication breakdown" + Exception
zaphnet
Which Emoticons are supported?
When adding "THINKING FACE" "\xF0\x9F\xA4\x94"
The System fails with core dump with JIRA 7.0.2
useUnicode=true&characterEncoding=UTF8&sessionVariables=storage_engine=InnoDB
Which verison of unicode is supported by which version of JIRA?
Nic Brough -Adaptavist-
August 30, 2017
MySQL doesn't support those extended emoji characters with JIRA.
Or the other way around - JIRA doesn't support them when backed by MySQL.
I don't know which one of those the fault lies with, but it's one of the two.  Either way, you can't use extended emojis with JIRA.
zaphnet
Thanks! - Migration to Postgres in the backlog - just got bumped up...
August 31, 2017
Ah, good, that's the first solution I would have offered!
Anton Derbenev̷̷̷̷̷̷͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇͇̊̊̊̊̊̊̊̊̊̊̊̊̌̌̌̌̌̌̌̌̌̌̌̌̌̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚̚
April 29, 2024
is that a bug which is going to be solved? Or is it by design? (very strange decision if it is)
April 29, 2024
No, it's a known problem with MySQL.  But fixable by configuring your MySQL to handle it correctly.
At the time the original question was asked, Jira would work with MySQL installs that were not set up correctly (which, annoyingly, is still the default settings for a  new MySQL install).
But later versions will not, so the problem has mostly gone away - new and upgrading users must correct the settings on their MySQL database before they can use Jira.
Nicolas Neumann May 16, 2024
Hi Nic,
thanks for this advise!
Could you provide us the necessary configuration on MySQL, please?
We've got the same issue still.
May 17, 2024
Hi Nicolas,
The settings for your MySQL server can be found in the installation guide at https://confluence.atlassian.com/adminjiraserver/connecting-jira-applications-to-mysql-8-0-1018775461.html
