i'm getting an error message when i try to import a csv file to JIRA: "Cannot add value [ [Compliance-Remediation] ] to CustomField Epic Link in Issue null. Probably value was in incorrect format". Can someone help?
We aren't support, most of us have other things to do, and we're not all in one time zone, give us time to catch up! I've not tested this, so I'm not sure, but I suspect the import expects the issue ID of the epic, not its name.
I've figured out the reason for this. i've not mentioned the Issue type. That caused this Error. Btw, even after mentioning the issue type (as Story), the stories are not getting added as part of epic.. instead only stories are getting created. Any help?
Hi, Prasad.
I'm not sure what is causing it, but maybe JIRA is not finding the 'Compliance-Remediation' Epic issue in your destination project.
Does it exist? If you create an epic with that Epic Name, does the import work?
Jaime Kirch da Silveira
Atlassian Cloud Support
