error when call ROBOTFRAMEWORK API for XRAY
seda_gurocak September 3, 2021 edited
I am trying to call API for robotframework in order to import Xray.
But when I call and send my request, I am getting error as "Your browser sent a request that this server could not understand."
I tried to call API both with Postman and curl (in addition Postman sometimes give 500 Internal server error)
POST Method and using form-data ( upload output.xml) (You can see screenshot)
URL : https://xxxxxx/jira/rest/raven/1.0/import/execution/robot?projectKey=TEST&testExecKey=TEST-394
and The curl;
curl -D- -u user:psw -X POST "https://xxxxx/jira/rest/raven/1.0/import/execution/robot?projectKey=TEST&testExecKey=TEST-208" -H "Content-Type:multipart/form-data" -F "file=@output.xml"
seda_gurocak September 20, 2021
I solved the issue. The problem is related the test which I have already created on Xray. Since it is a test created before, when I call the endpoint with the same output.xml again, it does not create it. You can close ticket. Thank you for your support
Rogério Paiva - Xray Xporter
September 7, 2021
Hi @seda_gurocak
The URL is wrong, it does not "jira" on it.
Wrong URLhttps://xxxxx/jira/rest/raven/1.0/import/execution/robot
  Right URLhttps://xxxxx/rest/raven/1.0/import/execution/robot
Any additional questions, please get in touch with Xray Support (http://xraysupport.getxray.app); we would gladly assist you.
Thank you.
Rogério Paiva [Xray Support Team]
seda_gurocak September 7, 2021
Thank you for your reply, but also I tried this url on POSTMAN. In that case, I am getting another error.
<head>
    <title>403 Forbidden</title>
</head>
<body>
    <h1>Forbidden</h1>
    <p>You don't have permission to access /rest/raven/1.0/import/execution/robot
        on this server.<br />
September 22, 2021
Hi @seda_gurocak
The problem could be related to the Test already created on Xray.
However, it will depend on the permission and configuration that you have, so in these specific cases, it is best to contact the Xray Support (http://xraysupport.getxray.app).
Thank you.
Register now
