error while installing atlassian-jira-4.4
Vishal Vijayan
August 17, 2011
I have downloaded atlassian-jira-4.4 on my Windows 7 prof comuter. When I try to install, it gives me a error
An internal error occured (error code :34)
Log C:\users\xyz\appdata\local\temp\i4j_nlog_10.
Please guide what is the above error.
FagnerF
August 23, 2012
Hi Tanaya,
Iit sounds the JIRA installer doesn't have any permission ("ERROR: check ReadFile failed 0 183 66583517") to procede the installation. You can dowload it once the newest JIRA (5.1.3) was released a few days ago including 64bit version for Windows, check out at Atlassian.
Kind Regards,
Tan Dew
August 15, 2012
Hello Guys ,
I am getting the same error . I am trying to install JIRA on Windows 7 64 bit machine . Please advice .
Nic Brough -Adaptavist-
August 15, 2012
The error message is a shade cryptic to a non-computer geek, but what it's saying is that the file you've downloaded is not the file the process is expecting and it can't work with it because it's damaged.
Try downloading it again and re-running the new copy.
August 17, 2011
Sounds like the installer is trying to do something it's not allowed to do, or is possibly corrupt. Try reading the log file it mentions, check the system events for errors, and re-downloading the installer.
Vishal Vijayan
August 17, 2011
The log file reads as - Started executable C:\atlassian-jira-4.4.exe at Thu Aug 18 18:30:13 2011
number of sections: 5
size of optional headers: 224
resSectionTableStart: 536
rawDataSize: 22016, rawDataOffset: 200704
change working directory to C:\
single instance mode
semaphore name c:_atlassian-jira-4.4.exe, code 0, value 00000074
Init done
Starting work
starting at 222720
verifying integrity length 152719172
Help us plant more trees
