×when trying to update the UPM i get the error:
An error was encountered while updating the UPM. Please see the logs for more details.
In the logs there is the following error:
There was an error loading the descriptor 'null' of plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin'. Disabling.
Caused by: java.lang.ClassNotFoundException: org.springframework.beans.factory.DisposableBean
the currently installed version of the upm is 2.7.8.
There is a bug in UPM 2.7.8 and 2.7.9 which causes the UPM update to fail. Please take a look at the following Knowledge Base article for a workaround.
Ben
This has been fixed in Confuence 2.7.10
CORRECTION - It has been fixed in the *Universal Plugin Manager* version 2.7.10 (not Confluence), which will be released later today.
This seems to be a bug in the latest version of the UPM. More infor and a workaround in https://ecosystem.atlassian.net/browse/UPM-2960
Same thing here.
The error log contains this kind of lines:
org.springframework.beans.factory.UnsatisfiedDependencyException: Error creating bean with name 'updateParametersFactory' defined in URL [bundle://115.0:0/META-INF/spring/atlassian-plugins-components.xml]: Unsatisfied dependency expressed through constructor argument with index 0 of type [com.atlassian.sal.api.pluginsettings.PluginSettingsFactory]: : Error loading class [com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager] for bean with name 'simpleAsyncTaskManager' defined in URL [bundle://115.0:0/META-INF/spring/atlassian-plugins-components.xml]: problem with class file or dependent class; nested exception is java.lang.NoClassDefFoundError: com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager not found from bundle [Atlassian Universal Plugin Manager Self-Update Plugin (com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin)]; nested exception is org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager] for bean with name 'simpleAsyncTaskManager' defined in URL [bundle://115.0:0/META-INF/spring/atlassian-plugins-components.xml]: problem with class file or dependent class; nested exception is java.lang.NoClassDefFoundError: com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager not found from bundle [Atlassian Universal Plugin Manager Self-Update Plugin (com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin)]
Caused by: org.springframework.beans.factory.CannotLoadBeanClassException: Error loading class [com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager] for bean with name 'simpleAsyncTaskManager' defined in URL [bundle://115.0:0/META-INF/spring/atlassian-plugins-components.xml]: problem with class file or dependent class; nested exception is java.lang.NoClassDefFoundError: com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager not found from bundle [Atlassian Universal Plugin Manager Self-Update Plugin (com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin)]
Caused by: java.lang.NoClassDefFoundError: com.atlassian.upm.selfupdate.async.SimpleAsyncTaskManager not found from bundle [Atlassian Universal Plugin Manager Self-Update Plugin (com.atlassian.upm.atlassian-universal-plugin-manager-selfupdate-plugin)]
Caused by: java.lang.NoClassDefFoundError: org/springframework/beans/factory/DisposableBean
just follow steps from above comment...in a different post...you will need to restart jira but it will work
you may try steps from my comment here
I am getting the same on this, voted up for you!
Yup same here. Check you installed-plugins dir. I got selfupdate twice in there. After removing it and clearing .bundeled&.osgi-plugins and resrarting jira still broken upm update. Also uploading manually is no work arround. I think this version is damaged Im pretty sure atlassian is goin to fix it soon
