×I want to be able to search for issues, and return both the issue data and the related properities of the issue
I *thought* that issue (ACJIRA-900) allowed you to specify a properties parameter, but I get no property data back, and the property definately exists, as a query to /issue/<id>/properties returns the data
Hi Julian,
Which property are you talking about?
It seems to work with most properties for me adding ?expand=<fields> but maybe there's some fields that are not supported?!
Best,
Maarten
Hi Maarten - I mean the "properties" of an issue , which can be got via /issue/<id>/properties or /issue/<id>?properties="*all"
Discussed here: https://community.developer.atlassian.com/t/issue-properties-with-jql-search-in-rest-api/60036
Any workaround for this?
