export attachments from JIRA_HOME of the project
Nenad Neshov
Hi guys,
I need help, how to download all attachments form the Issues in the project.
I can't install Bulk and to do it manual it's gonna take long time, because there is a lot of issues.
The attachemnts are stored in a folder structure in Jira_home according to ticket keys. I need to keep the structure with the ticket keys.
Please any suggestion is welcomed.
Regards
Cömek_ Dr_ Arif July 9, 2024
  1. You can use a filter as the following to find all the issues have attachment/s.
    • "project = PRJ6 AND issuetype = Bug AND attachmentsCount >=1"
  2. Click on the next/desired issue on the left side (the first one will be selected automatically after the filter is applied)
  3. Click on the 3 dots at the right side of the "Attachments"
  4. Select "Download all" even there is only 1 attachment
    • So, you have the file/s in a zip file with the name of the issue as in "PRJ6-1366_attachments" and keep the structure with the ticket keys.
  5. Repeat the steps 2-4 for all the issues found with the filter.
Of course always you can try one of the apps in Atlassian Market Place by searching
Attachments Manager .
Nenad Neshov
Screenshot 2024-07-09.jpg Is it okay like this, because am getting error, i can't add the filter.
Cömek_ Dr_ Arif July 9, 2024 edited
Please do not attempt to add a filter, just implement it and just use the JQL box to write the query directly, do not copy and past.
If you want to get the info and the fields of the issues, you can use "Export issues" button on the top right always.
Nenad Neshov
July 10, 2024 edited
Thanks for the help. Filter created.
Like Cömek_ Dr_ Arif likes this
Dick
USE YOURJIRADBNAME
DECLARE @@MDT nvarchar(255) = 'YOURPROJECTKEY'
SELECT fa.id, concat(p.pkey,'-',ji.issuenum) as 'Issue', st.pname as 'Status',
concat('/opt/jira-shareddata', '/data/attachments/', p.originalkey, '/', ceiling((ji.issuenum / 10000))* 10000, '/', p.originalkey, '-', ji.issuenum, '/', fa.id) as 'path',
fa.filename, cast(fa.FILESIZE/1024/1024 as decimal(18,2)) as 'Mb'
FROM fileattachment fa
join jiraissue ji on ji.id = fa.issueid
join issuestatus st on st.ID = ji.ISSUESTATUS
join project p on p.id = ji.project
WHERE cast(fa.FILESIZE/1024/1024 as decimal(18,2)) > 0.1 -- Filesize in Mb
--and ji.UPDATED < '2022-12-31 23:59:59'
--and p.pkey in (SELECT p.pkey FROM project p WHERE p.id NOT IN (select entity_id from propertyentry where property_key = 'jira.archiving.projects') ) -- non-archived project
and p.pkey = @@MDT
--and st.pname not in ( 'Done', 'Resolved')
ORDER BY
p.ID
--fa.FILESIZE desc
--fa.filename
Above is the MS-SQL script I'm using to get the issues containing attachments.
You get the IssueID, Issuekey, Status, Path, Filename and the size in Mb. The lines starting with dashes are optional filters and sortings to get on top of the attachments.
Dick
Hi Nenad,
For some reason my posted answer is wiped.
It describes the way how to retrieve filenames and locations on a project basis. I'll post it under this message, in the hope that it won't be deleted as malicious code.
Hi Dick,
I faced the similar issue and solved it by copying the text from Notepad and then pasting it to this area :)
Like Dick likes this
Dick
July 9, 2024 edited
cleaned up double post, apologies.
Dick
July 9, 2024 edited
