f5 reverse proxy issues including localhost
mike f July 10, 2017 edited
I am in charge of migrating our jira(6.2.3) to a new server behind an f5 proxy. This will be running as a service.
I am able to install jira 7.0, migrate the data, upgrade to 7.3.x with no issues. Once I request the server move(from our network team) to have it function through the proxy, localhost:8080 stops working. And I am not able to access it externally with our test link of JiraTest.Domain.com(junk domain) either.
I have attempted to update the "setenv.bat" section of "set JVM_SUPPORT_RECOMMENDED_ARGS=" To be:
-Dhttp.proxyHost=192.161.113.119 -Dhttp.proxyPort=8080 -Dhttps.proxyHost=192.161.113.119 -Dhttps.proxyPort=8443 -Dhttp.nonProxyHosts=localhost
rem --------------------------------------------------------------------------
 I know the proxy is working as I have to use the IP for internet browser settings to work. The Jira app wont accept them however.
I am not a network guy myself and dont know much of proxies, but I am hoping someone here can help with getting the settings working correctly. And maybe teach me a few things in the process.
Currently, the error that I get when I access localhost:8080 is
JIRA access problem
There is a problem with your JIRA access.
Description Time Level Exception
Unexpected exception during JIRA startup. This JIRA instance will not be able to recover. Please check the logs for details
Error logs show:
10-Jul-2017 09:06:00.446 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@3b2c436e]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@997cbe6]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
10-Jul-2017 09:06:00.446 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@36df2501]) and a value of type [com.atlassian.jira.web.filters.ThreadLocalQueryProfiler] (value [com.atlassian.jira.web.filters.ThreadLocalQueryProfiler@1cbd01c5]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
10-Jul-2017 09:06:00.446 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1f705a23]) and a value of type [com.atlassian.jira.issue.index.SearcherCache] (value [com.atlassian.jira.issue.index.SearcherCache@4331fde4]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
10-Jul-2017 09:06:00.446 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [webwork.action.ActionContext$1] (value [webwork.action.ActionContext$1@3b2c436e]) and a value of type [webwork.action.ActionContext] (value [webwork.action.ActionContext@75c63f05]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
10-Jul-2017 09:06:00.446 SEVERE [localhost-startStop-2] org.apache.catalina.loader.WebappClassLoaderBase.checkThreadLocalMapForLeaks The web application [ROOT] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@36df2501]) and a value of type [com.atlassian.jira.web.filters.ThreadLocalQueryProfiler] (value [com.atlassian.jira.web.filters.ThreadLocalQueryProfiler@423902a0]) but failed to remove it when the web application was stopped. Threads are going to be renewed over time to try and avoid a probable memory leak.
10-Jul-2017 09:06:00.451 INFO [Thread-5] org.apache.coyote.AbstractProtocol.stop Stopping ProtocolHandler ["http-nio-8080"]
10-Jul-2017 09:06:05.453 WARNING [Thread-5] org.apache.tomcat.util.net.AbstractEndpoint.shutdownExecutor The executor associated with thread pool [http-nio-8080] has not fully shutdown. Some application threads may still be running.
Nic Brough -Adaptavist-
July 11, 2017
The errors you have posted here are shut-down errors.  You need to look at the errors that occur on startup, and then when you try to hit the url and get the access problem report.
