field remains after moving ticket
Robin DiNunzio May 11, 2015
I am attempting to move a ticket from a project that contains the "Priority" field to a project that doesn't. However, upon completion of the move, the Priority field remains. Is there something I can do to prevent this? Thanks.
Deleted user May 11, 2015
"Priority" is a System Field and it is present on all tickets (just like the Summary and Description). Creating a ticket with no priority set will just have the default value.
Thank you! Wish there was a way to hide it!
MattS
May 11, 2015
You change that by creating a dummy priority, make it the default then delete it. Now there is no default priority
Nic Brough -Adaptavist-
May 11, 2015
Try setting the field "hidden" in the field configuration for the project.  That should minimise the amount of priority you see.
