×hi,
by viewing an issue the summary field is not visible in the details section.
It's defined in the assigned field configuration schema and the assigned screen mask.
Where can be the problem?
wolfgang reis
Hi Wolfgang,
In this case, I would like to ask you to create an issue at https://support.atlassian.com so we can further investigate your issue. Unfortunately, from the description of your issue is a little difficult to pinpoint exactly what is happening on your instance.
Thank you.
Kind Regards,
Clarissa Gautério
Atlassian Support
