After years of using JIRA, we have a lot of projects that are no longer actively being used. I can go through and search project by project to find the most recnet ticket created in each... I was just hoping for a more elegant solution. Maybe something which showed me the most recent issue in each project. Has anyone done something like this?
I do this by SQL Queries @Rodney
SELECT DISTINCT p.pkey,p.LEAD,MAX(i.UPDATED) as "Last Updated" FROM jiraissue i INNER JOIN project p ON p.ID = i.PROJECT GROUP BY p.pkey,p.LEAD ORDER BY MAX(i.UPDATED) ASC
Hope this helps
Cheers
Chander
I resorted to writing a report ages ago. It listed the projects with the most recently updated issue, date of oldest issue, ID (as that always increases when you create new projects, so you know the newest project is the highest number etc), and a couple of other bits related to it.
I keep meaning to re-develop it (it was a hack at the time, and for version 3.something), but things like sleep and paid work get in the way.
Sadly, I suspect your approach is already the best you can get without any coding, although if you've got script-runner or reporting tools, you should be able to do something.
Yeah, that is what I was thinking also. Maybe in some of my downtime I can put something together.
test
We used to have the same problem with our support packs projects, so we used Profields to give our projects a scripted field called Last Activity that records the last time something happenedd in the project. Maybe it could solve your problems and help you organice your projects better.
Regards
Hi!
In the last jira updates, as an admin you can see when was the last issue update in a project ( only admin view).
I copied the script from here, do not know if still works :).https://medium.com/@DEISERteam/5-soluciones-que-ofrece-profields-y-facilitar%C3%A1n-la-vida-a-los-administradores-de-jira-91abe905f8f2
import com.atlassian.jira.issue.search.SearchProvider
import com.atlassian.jira.issue.search.SearchRequest
import com.atlassian.jira.jql.builder.JqlQueryBuilder
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.component.ComponentAccessordef authContext = ComponentAccessor.jiraAuthenticationContext
def searchProvider = ComponentAccessor.getOSGiComponentInstanceOfType(SearchProvider.class)def user = authContext.getUser()
def lastUpdatedDate = new Date(Long.MIN_VALUE)try
def builder = JqlQueryBuilder.newBuilder()
builder.where().project(project.getId()) def query = builder.buildQuery()
def searchRequest = new SearchRequest(query)
def results = searchProvider.search(searchRequest.getQuery(), user, PagerFilter.getUnlimitedFilter()) def i = 0
for (Issue issue : results.getIssues())
def lastUpdated = issue.getUpdated()
if (i == 0 || lastUpdated > lastUpdatedDate)
lastUpdatedDate = lastUpdated
i++
catch (def ex)
logger.error("SCRIPT PROFIELDS FIELD: " + ex.getMessage())
return lastUpdatedDate
Thank you very much - I know that project view, but it is not able to sort or filter there... I need to review that code as it displays a weird date time result, but a good hint already!
