Hello community,
as you all know, there is no way to get the project creation date as it is not stored in Jira. I´d need your imagination over issue fiters in order to create a filter to show the first issue created of many proyects.
Thanks in advance
create a script to query the API in 4 steps
I hope it helps
Hello @Gonzalo Fernández Durán ,
in order to retrive those information you should perform a DB query because using JQL you can't do that using bultin capabilities.
Out of the box there is a third part app that could help you https://marketplace.atlassian.com/apps/1213501/sql-jql-driver-transform-jql-into-sql?hosting=server&tab=overview
Hope this helps,
Fabio
