from 'is blocked by' to 'blocks condition evatluation
Quinton Lephoto April 25, 2019
Good day friends, i have this code below that evaluates the issue links under the 'is blocked by' issues but now i need to redirect this to test for the 'block' issue types.
import com.atlassian.jira.issue.link.IssueLinkManager
import com.atlassian.jira.issue.link.IssueLink;
import com.opensymphony.workflow.InvalidInputException
IssueLinkManager linkMgr = ComponentAccessor.getIssueLinkManager()
if( linkMgr.getInwardLinks(issue.getId())*.issueLinkType.name.contains('Blocks') )
def counter = 0
for (IssueLink existingLink in linkMgr.getInwardLinks(issue.id))
def enh = existingLink.getSourceObject().getIssueType().toString().contains('Enhancement');
def sysEnh = existingLink.getSourceObject().getIssueType().toString().contains('System Enhancement');
def sto = existingLink.getSourceObject().getIssueType().toString().contains('Story');
def pro = existingLink.getSourceObject().getIssueType().toString().contains('Product');
def proIss = existingLink.getSourceObject().getIssueType().toString().contains('Production Issue');
def mis = existingLink.getSourceObject().getIssueType().toString().contains('MIS Story');
def bug = existingLink.getSourceObject().getIssueType().toString().contains('Bug');
if (enh || sysEnh || sto || pro || proIss || mis || bug)
counter++
if(counter > 0)
return true
