get all category created in jira
Karim Belhadj
hello team
I would like to get all category in instance jira and make it in a select list , maybe i need to work with behaviour .
Have some one idea how to do it , how to get category without using project ?
regards
Andrew
May 16, 2019
Hi @Karim Belhadj ,
Maybe direct from DB?
SELECT * FROM projectcategory;
B.R.
Karim Belhadj
how can i use it in script runner ?
regards
Andrew
May 16, 2019
In scriptConsole:
import groovy.sql.Sql
import org.ofbiz.core.entity.ConnectionFactory
import org.ofbiz.core.entity.DelegatorInterface
import java.sql.Connection
def delegator = (DelegatorInterface) ComponentAccessor.getComponent(DelegatorInterface)
String helperName = delegator.getGroupHelperName("default");
def sqlStmt = """
SELECT cname FROM projectcategory;
def result
Connection conn = ConnectionFactory.getConnection(helperName);
Sql sql = new Sql(conn)
try {
StringBuffer sb = new StringBuffer()
sql.eachRow(sqlStmt) {
sb << "${it.cname}; \n"
result = sb.toString()
//log.error sb.toString()
finally {
sql.close()
return result
Like # people like this
Karim Belhadj
@Andrew   thank you but : it works and i get the categorie of jira instance , but now i would like to make theese categorie in a select list custom field : i write this code but the problem is how i will call result to be option in the select list .
Please find below my code.
def sqlStmt = """
def result
try {
finally {
sql.close()
def optionsManager = ComponentAccessor.getOptionsManager()
def ParticipationTypeField = getFieldByName("Categorie") // your field name here
//Participation Type Field Options
def ParticipationTypeCF = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_10201"); // your field ID here
def ParticipationTypeConfig = ParticipationTypeCF.getRelevantConfig(getIssueContext());
def ParticipationTypeOptions = optionsManager.getOptions(ParticipationTypeConfig);
// Set the values inside the select list field
def ParticipationTypeMap = [null: "Noneeeeeee"]
ParticipationTypeMap += ParticipationTypeOptions.findAll {
it.value in [result, "c"]   ////////////////////// how can i make the value of the result in the option////////////////////////////////////
}.collectEntries {
[(it.optionId): it.value]
ParticipationTypeField.setFieldOptions(ParticipationTypeMap);
log.warn("***** ParticipationTypeOptions **** " + ParticipationTypeOptions);
regards
Andrew
May 16, 2019
Create textfield, in my example 'srselect'. Then create RestEnpoint:
import groovy.json.JsonOutput
import groovy.transform.BaseScript
import com.onresolve.scriptrunner.runner.rest.common.CustomEndpointDelegate
import javax.servlet.http.HttpServletRequest
import javax.ws.rs.core.MultivaluedMap
import javax.ws.rs.core.Response
@BaseScript CustomEndpointDelegate delegate
class position {
def value
def label
def sqlStmt = """
def resultSql = []
try {
resultSql.add(it.cname)
finally {
sql.close()
cats () { MultivaluedMap queryParams, String body,HttpServletRequest request ->
//def lista = ['1','2','3','4','5']
def result = []
def map = [:]
def i = 0
resultSql.each {
result << new position(value:it, label:it)
i++
map.put('items', result)
Response.ok(JsonOutput.toJson(map)).build()
And create 'behavior' with Initialiser:
getFieldByName("srselect").convertToSingleSelect([
ajaxOptions: [
url : getBaseUrl() + "/rest/scriptrunner/latest/custom/cats",
query: false,
formatResponse: "general",
css: "max-width: 500px; width: 500px",
Then mapping behavior to project.
For my it looks next:
B.R.
Karim Belhadj
hello @Andrew  thanks for response , but it still have a problem :
The text field works fine , but every time i add a new project category , and i go to create issue when i open the select list (srsselect) i find only the old options .. so i need every time to go to the endpoint rest and update the code to find after the right options .
I need your helps
Regards
Andrew
May 16, 2019
Change rest:
class position {
def value
def label
def sqlStmt = """
def resultSql = []
try {
finally {
sql.close()
def result = []
def map = [:]
def i = 0
resultSql.each {
i++
B.R.
Like Josh likes this
Karim Belhadj
Alexey Matveev i need your help please.
