get key instead key/summary in EazyBI report at rows
Bian Wu
November 3, 2016
Hi, I want to get only issue key instead of a long text with summary. How can I do that?
I tried [Issue].[Issue].CurrentHierarchy.Defaultmember.get("key") as a user defined Calculated members at rows in EazyBI report.
Martins Vanags_eazyBI
Hi Bian,
In that case, you could try the following code when creating new user-defined calculated member in "Measures" dimension
[Issue].CurrentHierarchy.Key
That would create issue property type of measure that would display results in a separate column but only for Issue dimension members.
And please note that for several chart types we have already now a functionality on the place to show only Issue key.
Please contact support@eazybi.com if you have further questions regarding this!
Martins Vanags / eazyBI
