hello
how can i get the issue types of a specific issue type screen that not associated a any project?
thanks
Hi Ramiro. Thank you for attention. But i wish the issue type screen that not associated to any project :/
i have this SQL, but it associated to one project
--issue type por projeto
SELECT IT.id, IT.pname
FROM configurationcontext CC
LEFT OUTER JOIN optionconfiguration OC ON OC.fieldconfig = CC.fieldconfigscheme
LEFT OUTER JOIN issuetype IT ON IT.id = OC.optionid
WHERE CC.project = 10000
and my goal is get the issuetypes of a specific issuetypescreen, and this issuetypescreen does not associated to any project.
Hi Cláudia if I understand correctly you have to go to Admin Section then Issue Types Schemes... There you will see what issue type are being used in what projects.
Hope this helps.
no. i'm sorry. my goal is get the issue types throug SQL command :/
i created an issue type screen with many issuetypes that i need, not for associate a project... i need these issetypes to use in another application that i'm creating.
do you understand?
I am not sure I understand your question properly. I think down the line you want to know which issue types are not being used in any of your projects, the issue type screens in this case are not really relevant. Could you formulate your question differently and in more detail?
but yes, i wish the issue types are not being used in any of your projects :)
do you understand?
