getCommentsForUser vs getComment which one to use and when ?
rkanumola June 6, 2016
As per getComment method comment of   CommentManager we need to use getCommentsForUser for permission checks, but I could not fine any difference. Can any one suggest a test that shows the problem with getComment would be grateful. Thanks in advance.
crf
June 6, 2016
This is in reference to the ability to restrict comments:
If you're making a request as a user that has permission to see all of the existing comments, then there would not be any difference.  If you have a project administrator restrict a comment to the Administrators role, then mere Developers should not be able to see it when you are using the method that enforces permission checks.
crf
June 6, 2016
One of our own tests for it goes something like this (edited for brevity):
when(mockProjectRoleManager.isUserInProjectRole(author, adminProjectRole, issueObject.getProjectObject())).thenReturn(false);
final ApplicationUser admin = new MockApplicationUser("Admin");
Comment comment = commentManager.create(issueObject, admin, "comment for admins", null, adminProjectRole.getId(), false);
final List<Comment> comments = commentManager.getCommentsForUser(issueObject, author);
assertEquals("User was NOT in the role so he should not see the comment", 0, comments.size());
rkanumola June 7, 2016
Thanks for the great response Chris Fuller  with sample testcases !!.
