getting different status results for same ticket
Lingesh BN July 3, 2015
getting different status results for same ticket.
when we query the ticket with filters i am seeing the status as verification needed.
but when i open the same ticket directly the status is verified could you plesae help on thischecking ticket directly status is different.PNG attaching the screen shot.
please check the status in both the screen shots which shows different for same ticket
crf
July 3, 2015
Searches go to a Lucene index while the view issue page goes to the database.  Inconcsistent results like this indicate that the information in the Lucene index is stale.
There may be a more serious underlying problem here, but if there is a single issue affected that you want to fix, the easiest way is to make a superficial change to the issue, like adding a label to it or editing whitespace in the description.  This forces the index to be updated, which would make the results consistent again.
Nic Brough -Adaptavist-
July 3, 2015
I would have typed something saying the same myself, but I'd emphasise the point that there may be a more serious underlying problem. Indices that don't match the database strongly suggest a structural problem. The usual suspects are server interruptions (accidental reboot, power loss, forced kill of JIRA), bad code in plugins, bad code plumbed into scripts, or the favourite - someone has written to the database outside JIRA (Hint - don't. Don't ever do that)
Lingesh BN July 8, 2015
Hi All,
Thanks for your suggestions.
For temporary we moved the tickets to different project and added to the same project it worked.
Permanently we fixed this issue by doing full reindexing.
regards
lingesh
July 8, 2015
Ah, no, you have probably not "permanently fixed it" - you don't know what the *cause* of the broken index was. Because you don't know the cause, you haven't changed anything to fix it, so you could easily end up with more broken issues. You may not see it again, it may have been a one-off cause. But you don't know that.
Nicolas Bourdages
July 3, 2015
There is no normal reason why a status would be different in the View screen than in query results.
We once experienced something similar when an issue had been reported just as we were publishing a new workflow. The issue was stuck in an indefinite status and couldn't be transitioned out.
Your issue might be corrupted in some way. Try a Move operation on that issue. You can move the issue to another project or issue type, and then back again to the original project and issue type.
If that doesn't resolve your problem, or if there are multiple issues with the same problem, I suggest you open a ticket with Atlassian Support. They can look at your logs and backup data if necessary and see if there's corrupted data.
Register today
