getting message like Plug-in yet to be enabled while using atlas-run command
vimala nunavath June 12, 2012
I am developing a report plugin for jira 5.0. when I used atlas-run command, I got the following timedout error. Could anyone help me to solve it.
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,146 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.rest.atlassian-rest-module, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,146 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.plugins.rest.atlassian-rest-module], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#1]), Dependency on [(objectClass=com.atlassian.sal.api.websudo.WebSudoManager)] (from bean [&org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#2]), Dependency on [(objectClass=com.atlassian.sal.api.net.NonMarshallingRequestFactory)] (from bean [&requestFactory])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.plugins.rest.atlassian-rest-module' has timed out
[INFO] [talledLocalContainer] at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.timeout(DependencyWaiterApplicationContextExecutor.java:454)
[INFO] [talledLocalContainer] at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.access$000(DependencyWaiterApplicationContextExecutor.java:50)
[INFO] [talledLocalContainer] at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$WatchDogTask.run(DependencyWaiterApplicationContextExecutor.java:105)
[INFO] [talledLocalContainer] at java.util.TimerThread.mainLoop(Timer.java:555)
[INFO] [talledLocalContainer] at java.util.TimerThread.run(Timer.java:505)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,147 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#1' for plugin 'com.atlassian.plugins.rest.atlassian-rest-module' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,147 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&org.springframework.osgi.service.importer.support.OsgiServiceProxyFactoryBean#2' for plugin 'com.atlassian.plugins.rest.atlassian-rest-module' with filter (objectClass=com.atlassian.sal.api.websudo.WebSudoManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,147 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&requestFactory' for plugin 'com.atlassian.plugins.rest.atlassian-rest-module' with filter (objectClass=com.atlassian.sal.api.net.NonMarshallingRequestFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,147 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.plugins.rest.atlassian-rest-module
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,147 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.plugins.rest.atlassian-rest-module, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,217 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.soy.template-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,217 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.soy.template-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.soy.template-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,218 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.soy.soy-template-plugin' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,218 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.soy.soy-template-plugin' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,218 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.soy.soy-template-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,218 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.soy.template-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,431 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,431 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.aggregator-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)] (from bean [&formatPreferenceProvider]), Dependency on [(objectClass=com.atlassian.sal.api.scheduling.PluginScheduler)] (from bean [&pluginScheduler]), Dependency on [(objectClass=com.atlassian.applinks.api.EntityLinkService)] (from bean [&entityLinkService]), Dependency on [(objectClass=com.atlassian.streams.api.builder.StreamsFeedUriBuilderFactory)] (from bean [&streamsFeedUriFactory]), Dependency on [(objectClass=com.atlassian.streams.spi.StreamsI18nResolver)] (from bean [&streamsI18nResolver]), Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)] (from bean [&transactionTemplate]), Dependency on [(objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)] (from bean [&templateRendererFactory]), Dependency on [(objectClass=com.atlassian.sal.api.net.RequestFactory)] (from bean [&requestFactory]), Dependency on [(objectClass=com.atlassian.templaterenderer.TemplateRenderer)] (from bean [&templateRenderer]), Dependency on [(objectClass=com.atlassian.sal.api.executor.ThreadLocalDelegateExecutorFactory)] (from bean [&executorFactory]), Dependency on [(objectClass=com.atlassian.applinks.api.ApplicationLinkService)] (from bean [&applinkService]), Dependency on [(objectClass=com.atlassian.streams.spi.DelegatingSessionManager)] (from bean [&sessionManager]), Dependency on [(objectClass=com.atlassian.streams.spi.EntityResolver)] (from bean [&entityResolvers])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.aggregator-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,433 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&formatPreferenceProvider' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.FormatPreferenceProvider)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,433 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&pluginScheduler' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.scheduling.PluginScheduler)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,434 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityLinkService' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.applinks.api.EntityLinkService)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,434 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsFeedUriFactory' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.api.builder.StreamsFeedUriBuilderFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,434 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsI18nResolver' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.StreamsI18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,434 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,435 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,435 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&transactionTemplate' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,435 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&templateRendererFactory' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,436 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&requestFactory' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.net.RequestFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,436 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&templateRenderer' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.templaterenderer.TemplateRenderer)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,436 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&executorFactory' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.sal.api.executor.ThreadLocalDelegateExecutorFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,436 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applinkService' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.applinks.api.ApplicationLinkService)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,437 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&sessionManager' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.DelegatingSessionManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,437 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&entityResolvers' for plugin 'com.atlassian.streams' with filter (objectClass=com.atlassian.streams.spi.EntityResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,437 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,438 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.aggregator-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,470 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,470 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.inline-actions-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)] (from bean [&streamsLocaleProvider]), Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.inline-actions-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,471 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsLocaleProvider' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.streams.spi.StreamsLocaleProvider)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,471 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.streams.actions' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,471 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.actions
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,471 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.inline-actions-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.core-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.core-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)] (from bean [&templateRendererFactory]), Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.sal.api.message.LocaleResolver)] (from bean [&localeResolver]), Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.core-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&templateRendererFactory' for plugin 'com.atlassian.streams.core' with filter (objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.streams.core' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&localeResolver' for plugin 'com.atlassian.streams.core' with filter (objectClass=com.atlassian.sal.api.message.LocaleResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.streams.core' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,479 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.core
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,480 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.core-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,509 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.streams.streams-thirdparty-plugin, com.atlassian.support.stp, crowd-rest-application-management, com.atlassian.jirafisheyeplugin, crowd-rest-plugin, com.atlassian.streams.streams-jira-plugin, com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin, com.atlassian.templaterenderer.api, com.atlassian.upm.atlassian-universal-plugin-manager-plugin, com.atlassian.jira.whatsnew.jira-whatsnew-plugin], 0 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,608 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,608 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.jira-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.gadgets.view.GadgetViewFactory)] (from bean [&gadgetViewFactory]), Dependency on [(objectClass=com.atlassian.streams.api.renderer.StreamsEntryRendererFactory)] (from bean [&streamsEntryRendererFactory]), Dependency on [(objectClass=com.atlassian.sal.api.timezone.TimeZoneManager)] (from bean [&timeZoneManager]), Dependency on [(objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)] (from bean [&gadgetRequestContextFactory]), Dependency on [(objectClass=com.atlassian.streams.spi.StreamsI18nResolver)] (from bean [&streamsI18nResolver]), Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)] (from bean [&templateRendererFactory])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.jira-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,610 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,610 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetViewFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.view.GadgetViewFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,610 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsEntryRendererFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.streams.api.renderer.StreamsEntryRendererFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,615 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&timeZoneManager' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.sal.api.timezone.TimeZoneManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,616 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&gadgetRequestContextFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.gadgets.GadgetRequestContextFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,616 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsI18nResolver' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.streams.spi.StreamsI18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,616 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,617 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&templateRendererFactory' for plugin 'com.atlassian.streams.streams-jira-plugin' with filter (objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRendererFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,617 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-jira-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,619 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.jira-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,640 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,641 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.streams.thirdparty-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.activeobjects.external.ActiveObjects)] (from bean [&ao]), Dependency on [(objectClass=com.atlassian.streams.spi.UserProfileAccessor)] (from bean [&userProfileAccessor]), Dependency on [(objectClass=com.atlassian.streams.spi.StreamsI18nResolver)] (from bean [&streamsI18nResolver]), Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.streams.api.FeedContentSanitizer)] (from bean [&feedSanitizer]), Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)] (from bean [&transactionTemplate]), Dependency on [(objectClass=com.atlassian.streams.spi.DelegatingSessionManager)] (from bean [&sessionManager])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.streams.thirdparty-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&ao' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.activeobjects.external.ActiveObjects)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userProfileAccessor' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.UserProfileAccessor)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&streamsI18nResolver' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.StreamsI18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&feedSanitizer' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.api.FeedContentSanitizer)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,642 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,643 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&transactionTemplate' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,643 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&sessionManager' for plugin 'com.atlassian.streams.streams-thirdparty-plugin' with filter (objectClass=com.atlassian.streams.spi.DelegatingSessionManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,643 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.streams.streams-thirdparty-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,643 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.streams.thirdparty-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,794 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.templaterenderer.atlassian-template-renderer-api, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,794 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.templaterenderer.atlassian-template-renderer-api], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.templaterenderer.atlassian-template-renderer-api' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,795 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.templaterenderer.api' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,795 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.templaterenderer.api
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,796 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.templaterenderer.atlassian-template-renderer-api, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,799 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.support.stp, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,799 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.support.stp], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver]), Dependency on [(objectClass=com.atlassian.sal.api.websudo.WebSudoManager)] (from bean [&salWebSudoManager]), Dependency on [(objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRenderer)] (from bean [&renderer]), Dependency on [(objectClass=com.atlassian.sal.api.auth.LoginUriProvider)] (from bean [&loginUriProvider])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.support.stp' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&salWebSudoManager' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.sal.api.websudo.WebSudoManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderer' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRenderer)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,800 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&loginUriProvider' for plugin 'com.atlassian.support.stp' with filter (objectClass=com.atlassian.sal.api.auth.LoginUriProvider)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,801 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.support.stp
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,801 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.support.stp, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,814 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.templaterenderer.atlassian-template-renderer-velocity16-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,814 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.templaterenderer.atlassian-template-renderer-velocity16-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.templaterenderer.TemplateContextFactory)] (from bean [&templateContextFactory])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.templaterenderer.atlassian-template-renderer-velocity16-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,815 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&templateContextFactory' for plugin 'com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin' with filter (objectClass=com.atlassian.templaterenderer.TemplateContextFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,815 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:25,815 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.templaterenderer.atlassian-template-renderer-velocity16-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,363 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.crowd.rest-application-management, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,363 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.crowd.rest-application-management], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.crowd.rest-application-management' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,364 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'crowd-rest-application-management' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,364 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'crowd-rest-application-management' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,364 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin crowd-rest-application-management
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,365 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.crowd.rest-application-management, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,467 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.crowd.rest-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,467 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.crowd.rest-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.crowd.rest-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,468 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'crowd-rest-plugin' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,468 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin crowd-rest-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,469 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.crowd.rest-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,474 Timer-0 WARN [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Timeout occurred before finding service dependencies for [NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.upm.atlassian-universal-plugin-manager-plugin, config=osgibundle:/META-INF/spring/*.xml)]
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,474 Timer-0 ERROR [internal.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.upm.atlassian-universal-plugin-manager-plugin], unsatisfied dependencies: Dependency on [(objectClass=com.atlassian.sal.api.user.UserManager)] (from bean [&userManager]), Dependency on [(objectClass=com.atlassian.sal.api.message.LocaleResolver)] (from bean [&localeResolver]), Dependency on [(objectClass=com.atlassian.sal.api.ApplicationProperties)] (from bean [&applicationProperties]), Dependency on [(objectClass=com.atlassian.sal.api.message.I18nResolver)] (from bean [&i18nResolver]), Dependency on [(objectClass=com.atlassian.sal.api.auth.LoginUriProvider)] (from bean [&loginUriProvider]), Dependency on [(objectClass=com.atlassian.sal.api.scheduling.PluginScheduler)] (from bean [&salPluginScheduler]), Dependency on [(objectClass=com.atlassian.sal.api.net.RequestFactory)] (from bean [&requestFactory]), Dependency on [(objectClass=com.atlassian.sal.api.pluginsettings.PluginSettingsFactory)] (from bean [&pluginSettingsFactory]), Dependency on [(objectClass=com.atlassian.sal.api.websudo.WebSudoManager)] (from bean [&salWebSudoManager]), Dependency on [(objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRenderer)] (from bean [&renderer]), Dependency on [(objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)] (from bean [&txTemplate])
[INFO] [talledLocalContainer] org.springframework.context.ApplicationContextException: Application context initialization for 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' has timed out
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,476 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&userManager' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.user.UserManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,476 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&localeResolver' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.message.LocaleResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,476 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&applicationProperties' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.ApplicationProperties)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,476 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&i18nResolver' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.message.I18nResolver)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,477 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&loginUriProvider' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.auth.LoginUriProvider)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,477 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&salPluginScheduler' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.scheduling.PluginScheduler)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,477 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&requestFactory' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.net.RequestFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,477 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&pluginSettingsFactory' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.pluginsettings.PluginSettingsFactory)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,477 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&salWebSudoManager' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.websudo.WebSudoManager)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,478 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&renderer' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.templaterenderer.velocity.one.six.VelocityTemplateRenderer)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,478 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Never resolved service '&txTemplate' for plugin 'com.atlassian.upm.atlassian-universal-plugin-manager-plugin' with filter (objectClass=com.atlassian.sal.api.transaction.TransactionTemplate)
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,478 Timer-0 ERROR [plugin.osgi.factory.OsgiPlugin] Unable to start the Spring context for plugin com.atlassian.upm.atlassian-universal-plugin-manager-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,479 Timer-0 ERROR [extender.internal.activator.ContextLoaderListener] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.upm.atlassian-universal-plugin-manager-plugin, config=osgibundle:/META-INF/spring/*.xml))
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,510 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.streams.streams-thirdparty-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,511 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.support.stp
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,511 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling crowd-rest-application-management
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,512 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.jirafisheyeplugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,516 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling crowd-rest-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,517 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.streams.streams-jira-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,518 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,518 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.templaterenderer.api
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,518 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.upm.atlassian-universal-plugin-manager-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,518 main INFO [atlassian.plugin.manager.DefaultPluginManager] Disabling com.atlassian.jira.whatsnew.jira-whatsnew-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,521 main ERROR [atlassian.plugin.manager.PluginEnabler] Unable to start the following plugins due to timeout while waiting for plugin to enable: com.atlassian.streams.streams-thirdparty-plugin,com.atlassian.support.stp,crowd-rest-application-management,com.atlassian.jirafisheyeplugin,crowd-rest-plugin,com.atlassian.streams.streams-jira-plugin,com.atlassian.templaterenderer.atlassian-template-renderer-velocity1.6-plugin,com.atlassian.templaterenderer.api,com.atlassian.upm.atlassian-universal-plugin-manager-plugin,com.atlassian.jira.whatsnew.jira-whatsnew-plugin
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,676 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:26,676 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\commons-fileupload-1.2.1.jar (1339578492850) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:27,002 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\developer-toolbox-plugin-1.1.jar (1339578493916) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:27,508 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\fastdev-plugin-1.9.1.jar (1339578493864) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:27,685 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:27,685 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\httpservice-bridge-0.6.1.jar (1339578493671) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:27,880 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\jira-report-plugin-1.0.jar (1339578475883) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,052 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,052 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\org.apache.felix.webconsole-1.2.8.jar (1339578493382) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,134 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,134 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\org.osgi.compendium-1.2.0.jar (1339578493531) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,301 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\pdkinstall-plugin-0.4.jar (1339578492842) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,606 main INFO [atlassian.plugin.loaders.ScanningPluginLoader] Plugin Unit: C:\atlassian-plugin-sdk\bin\jira-report-plugin\target\jira\home\plugins\installed-plugins\plugin-data-editor-1.2.jar (1339578494102) created
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,619 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,635 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,648 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,660 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,671 main INFO [plugin.util.resource.AlternativeDirectoryResourceLoader] Found alternative resource directory C:\atlassian-plugin-sdk\bin\jira-report-plugin\src\main\resources
[INFO] [talledLocalContainer] 2012-06-13 11:12:28,925 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 60 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:29,926 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 58 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:30,926 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 57 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:31,926 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 56 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:32,927 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 55 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:33,927 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 54 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:34,927 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 53 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:35,927 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 52 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:36,927 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 51 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:37,928 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 50 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:38,928 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 49 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:39,928 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 48 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:40,928 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 47 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:41,928 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 46 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:42,929 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 45 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:43,929 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 44 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:44,929 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 43 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:45,929 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 42 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:46,929 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 41 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:47,930 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 40 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:48,930 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 39 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:49,930 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 38 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:50,930 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 37 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:51,930 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 36 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:52,931 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 35 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:53,931 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 34 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:54,931 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 33 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:55,932 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 32 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:56,932 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 31 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:57,933 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 30 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:58,933 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 29 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:12:59,933 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 28 seconds remaining
[INFO] [talledLocalContainer] 2012-06-13 11:13:00,933 main INFO [atlassian.plugin.util.WaitUntil] Plugins that have yet to be enabled: [com.atlassian.devrel.developer-toolbox-plugin, com.atlassian.labs.fastdev-plugin, com.atlassian.plugins.plugin-data-editor], 27 seconds remaining
[INFO] ------------------------------------------------------------------------
[ERROR] BUILD ERROR
[INFO] Unable to execute mojo
Deployable [http://localhost:2990/cargocpc/index.html] failed to finish deploying within the timeout period [180000]. The Deployable state is thus unknown.
[INFO] For more information, run Maven with the -e switch
[INFO] Total time: 5 minutes 21 seconds
[INFO] Finished at: Wed Jun 13 11:13:01 CEST 2012
[INFO] Final Memory: 67M/300M
[WARNING] [talledLocalContainer] Java Result: 1
C:\atlassian-plugin-sdk\bin\jira-report-plugin>
Thnaks for the helo in advance.
Vimala
Manjunath Kanakagiri July 16, 2014
Is this issue still as is?
