groovy post function clone and set datepicker customfield
Kevin Lynch May 1, 2013
I'm having issues setting a custom datepicker field from the groovy post function Clones an issue and links.
Condition: blank
Target Project: Different Project name
Target Issue Type: New Issue Type
Additional issue actions:
def cf = customFieldManager.getCustomFieldObjects(issue).find {it.name == 'Start Date'}
issue.setCustomFieldValue(cf.id, '2012-09-17 00:00:00.0')
Issue Link Type: New Plan
Log error:
Caused by: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setCustomFieldValue() is applicable for argument types: (java.lang.String, java.lang.String) values: [customfield_10434, 2012-09-17 00:00:00.0]
Possible solutions: setCustomFieldValue(com.atlassian.jira.issue.fields.CustomField, java.lang.Object), getCustomFieldValue(com.atlassian.jira.issue.fields.CustomField)
I've also tried
issue.setCustomFieldValue(cf.id, '30/Apr/13')
Log error:
Caused by: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setCustomFieldValue() is applicable for argument types: (java.lang.String, java.lang.String) values: [customfield_10434, 30/Apr/13]
The server shows the date picker field as DD/MMM/YY when being filled out.
I'm using version script runner 2.1.3
Kevin Lynch May 2, 2013
Thanks Jamie,
import java.sql.Timestamp
issue.setCustomFieldValue(cf, new Timestamp(new Date(2012,9,17).getTime()))
That worked. I was able to construct my final piece of getting a different date picker field to populate to a different date picker field by putting the following.
issue.summary = 'Equipment Order (automatic ticket)'
issue.setCustomFieldValue(cf, cfValues['Effective Date'])
oh Jamie, if you could convert one of your comments to answer, I'll accept it. Thanks
And thanks to Henning for your assist
JamieA
May 2, 2013
Try this:
Henning Tietgens
May 1, 2013
I think you have to use a Timestamp (or Date) object as value to set. You can easily see the needed object if you call getValue() on the customfield an examine the returned object.
log.error cf.getValue(issue).class.name
If you now look into the log you will see the needed object for setting the value.
Henning
alright, I 'think' that it is saying it needs a timestamp. I ran the following through the script runner at the ticket in question.
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
CustomFieldManager customFieldManager = ComponentManager.getInstance().getCustomFieldManager()
issueOld = ComponentManager.getInstance().getIssueManager().getIssueObject("HR-823")
def cf = customFieldManager.getCustomFieldObjectByName("Start Date")
def rt = issueOld.getCustomFieldValue(cf)
log.error cf.getValue(issueOld).class.name
rt
and it came back with this in the log
Caused by: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: java.sql.Timestamp.getValue() is applicable for argument types: (com.atlassian.jira.issue.IssueImpl) values: [HR-823]
Possible solutions: getDate(), getClass(), getDay(), getTime(), getNanos(), getTime()
and this value on the output
I also dumbied down my 'Additional Issue Actions' to
issue.setCustomFieldValue("customfield_10434", '2012-09-17 00:00:00.0')
and I get this in the log
javax.script.ScriptException: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setCustomFieldValue() is applicable for argument types: (java.lang.String, java.lang.String) values: [customfield_10434, 2012-09-17 00:00:00.0]
I also tried
issue.description = '\nStart Date=' + cfValues['Start Date'] + '='
to make sure the output didn't have any hidden characters or spaces. Output was
Start Date=2013-04-30 00:00:00.0=
As you can see the output is the same format as the value I'm trying to set.
Henning Tietgens
May 1, 2013
I cannot reproduce your ScriptExecption, for me your script works well.
But, you have to use a Date object for setting. Currently you are using a String.
Try
new Date(2012,9,17)
as value for setCustomFieldValue()
Henning
I tried
new Date(2012,9,17)
issue.setCustomFieldValue(cf.id, Date)
and I got
Caused by: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setCustomFieldValue() is applicable for argument types: (java.lang.String, java.lang.Class) values: [customfield_10434, class java.util.Date]
Henning Tietgens
May 1, 2013
issue.setCustomFieldValue(cf.id, new Date(2012,9,17))
Try this.
First off, I REALLY appreciate your help on this. I put that in and got
Caused by: javax.script.ScriptException: groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setCustomFieldValue() is applicable for argument types: (java.lang.String, java.util.Date) values: [customfield_10434, Thu Oct 17 00:00:00 PDT 3912]
Henning Tietgens
May 1, 2013
You're welcome :-)
Oh, I see.. you have to use the customfield itself for setCustomFieldValue() and not the Id of the customfield. So try
issue.setCustomFieldValue(cf, new Date(2012,9,17))
Henning
tried your code and got
Caused by: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:CustomFieldValue][id,6924947][datevalue,Thu Oct 17 00:00:00 PDT 3912][issue,605122][parentkey,null][customfield,10434] (Java type java.util.Date not currently supported. Sorry.)
produced this log entry
Caused by: org.codehaus.groovy.control.MultipleCompilationErrorsException: startup failed:
Script2.groovy: 2: unable to resolve class Timestamp
 @ line 2, column 31.
the '^' is pointing at the 'new' of 'new Timestamp'
JamieA
May 2, 2013
Henning Tietgens
May 2, 2013
Thanks Jamie for pitching in (and for your vote) while I was enjoying my leisure time.. :-)
