help with a script
Christian Jaya May 8, 2018
Hi is me again
i'm using Scriptrunner with groovy programing, i need to copy a "summary" systemfield, into a customfield for to make a validation, please can you help me, how can i do that?
if you have a Little script that help me with this trouble, send it please
thank you so much
Marcos Sanchez
May 8, 2018
Why do yo need to copy the summary to make the validation?
What are you trying to do?
The summary can be get with a script directly without needing to copy it to another field.
Marcos
Christian Jaya May 8, 2018 edited
As i said i'm a begginer in this lenguaje, please can you explain me, how i get the "summary" with a script,
and please another cuestion, is posible use this "summary" in a sql sentence???
please help me with that thank you
Marcos Sanchez
May 8, 2018 edited
To get the summary you can use this:
def issueSummary = issue.getSummary()
For you second question:
Yes, you can. Do you want to do it in the same script?
Note that using issue will mark it as an error, but it's a false positive unless you are running the script on Script Console.
Btw, tell me what you want to do so I can do a full script and show it to you.
Marcos
Thank you so much
And yes i want to do this in the same script, i'm using ScriptRunner for JIRA
answering your question, a need to use the "Summary" to make a SQL sentece like this
SELECT id,Summary,due FROM jiraissue WHERE Summary = issueSummary
Christian Jaya May 9, 2018
Hello
yesterday i wrotte to you, and i don't recive an answer, please help me, i need to know how to do this
thank you so much for your answer
Nic Brough -Adaptavist-
May 9, 2018
Forget the SQL, it's slow, complex, painful and not needed for what you're trying to do.
issue.getSummary returns the summary.  Try issue.getKey() and issue.getDueDate for the others.
Marcos Sanchez
May 9, 2018
Sorry I was busy and ran out of time.
I was going to answer the same as Nic did.
Marcos
Thank you so much
only one more cuestion, there are a function issue.getAssignee??
that is the field that I need
Marcos Sanchez
May 9, 2018
Yes.
In this link you have all JIRA issue API.
Marcos
that is so help full
there are a librari that i have to import to use the sentece issue.getAssignee??
Marcos Sanchez
May 9, 2018
No, you don't have to import a library to use it except that you run the script on the Script Console.
If you run the script as Listener, Script Field, Behaviour or Workflow you don't have to import a library to use the issue api.
Marcos
Christian Jaya May 14, 2018
Marcos how are you??
please can you help me???
i have this error and i dont know what is it
java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SqlServerDriver
i download a java driver from microsoft and define the ClassPath, but the error are still there
please help me
Regards
Marcos Sanchez
May 14, 2018
I recommend you to open a new ticket if this is an other problem, because maybe some expert could help you more than me.
Marcos
