how automatically start and stop sprints same day every week
Tomas Arguinzones Yahoo
Hi...I need some guidance about whether it is possible to automatically start and stop our sprints without any manual intervention. All our sprints start Thursday and end Wednesday the following week. Can something like that be accomplished with scriptrurner? Our JIRA instance is a Data Center instance with 2 nodes, version 7.1.4. Scriptrunner is 4.3.13
Thank you for your assistance
3 votes
Thanos Batagiannis [Adaptavist]
December 15, 2016
Hi Tomas,
Interesting question / automation smile
Probably you will need one or two ScriptRunner Service running a script every <Choose day>. The script for closing a sprint should be something like
import com.atlassian.greenhopper.service.sprint.Sprint
import com.atlassian.greenhopper.service.sprint.SprintManager
import com.onresolve.scriptrunner.runner.customisers.PluginModuleCompilationCustomiser
import com.onresolve.scriptrunner.runner.customisers.WithPlugin
@WithPlugin("com.pyxis.greenhopper.jira")
def sprintServiceOutcome = PluginModuleCompilationCustomiser.getGreenHopperBean(SprintManager).getAllSprints()
if (sprintServiceOutcome.valid) {
    sprintServiceOutcome.getValue().findAll { it.state == Sprint.State.ACTIVE }?.each { updateSprintState(it, Sprint.State.CLOSED) }
else {
    log.error "Invalid sprint service outcome, ${sprintServiceOutcome.errors}"
def updateSprintState(Sprint sprint, Sprint.State state) {
    def sprintManager = PluginModuleCompilationCustomiser.getGreenHopperBean(SprintManager)
    def newSprint = sprint.builder(sprint).state(state).build()
    def outcome = sprintManager.updateSprint(newSprint)
    if (outcome.isInvalid()) {
        log.debug "Could not update sprint with name ${sprint.name}, ${outcome.getErrors()}"
    } else {
        log.debug "${sprint.name} updated."
So the above script is a guide on how to update sprints. I suppose it will require some more logic, but you can build on this. Please let me know if you need further assistance.
regards, Thanos
Hello Thanos...thank you for your reply...thats great!
I kinda get the logic behind that script but I do have a couple of questions. The idea is that the script has to "loop" and find all active sprints and close them so I dont see any looping in that script. And the sprint names change every week so I see in that script def SPRINT_NAME = "Sample Sprint 2", but I cant put a fix sprint name, can I? The sprint names change every week and the script should find all active sprints and close them the day the script runs, thats the idea.
Thank you very much for your help
December 15, 2016
Hey Thomas,
I updated the script above in order to close all the active sprints.
The script to make active future sprints should be very similar. You will need to 'play' with the states.
Hi Thanos...thank you very much for your help.
I will give it a try and let you know how it went.
Thank you
Hi Thanos...I just wanted to let you know that I was able to test the script to automatically close all active sprints and it worked as a charm! Thank you very much for your assistance.
I will try to create one to activate future sprints and let you know if I have any questions.
Thanks a lot for your help!
Hi there...I have a question regarding this script....how can I see the sprints that were closed when the script runs? is there any log I can check to see if the script ran, if there were any issues, and the sprints that were closed?
Thank you
February 17, 2017
hi Tomas,
You can add in the each closure a debug message
log.debug "Issue key to be updated : ${it.key}"
And then you can check your Atlassian logs. First you have to set the debugging level for JIRA to DEBUG
Yogesh Mude
April 2, 2019
Hey @Thanos Batagiannis [Adaptavist]
Thanks for the above script...as you mentioned in your comment we need to add a service and it will run at regular basis to close the sprint.
We are looking like whenever the sprint close/complete date will reach the sprint should auto close.
Meghan Stovall
September 13, 2021
Hi @Thanos Batagiannis [Adaptavist]
I am trying to use this script to auto stop and start sprints. I am extremely new to ScriptRunner. I could be wrong but this script doesn't handle when issues are still in the previous sprint but not done correct? I am trying to figure out how to find any issues in the current sprint that aren't closed, then close the sprint, start the next sprint, and move those found issues to the new sprint. Is there a better order and/or way to do this?
3 votes
Siavash Mehrabi
March 10, 2019
There is a feature request directly related to this question that you can vote for it:
https://jira.atlassian.com/browse/JSWSERVER-11569
I think this really needs to be a built-in feature for Jira.
Jussi Niutanen January 28, 2022
I have a crontab in Azure server and Python script to stop and start sprints automatically https://github.com/JussiNiutanen/JiraPython
I hope this helps.
Best,
Jussi
